intermittent starting issue
Old Dec 15, 2017 | 09:06 PM
KHflatbed's Avatar
KHflatbed
1988 F super Duty, 7.5L gas EFI. dual tanks, manual trans.
Sometimes, not regular, when the truck has been off for between 5-15/30 minutes, it won't start. Cranks like it wants to start. This happens with the fuel tank selector switch in either tank.
I've replace the external fuel pump, fuel tank selector valve, fuel pressure regulator, both sending units {front & rear tanks}, recently replaced the ignition coil, and spark plugs, and distributor cap, ignition modules [on the steering column. About a yr ago I replaced the TFI module.
If i let the system sit for 5 minutes after cranking several times, it starts.
Any suggestions?
Old Dec 16, 2017 | 09:02 AM
vjsimone's Avatar
vjsimone
What happens if you use starting fluid ?
Old Dec 16, 2017 | 09:36 AM
KHflatbed's Avatar
KHflatbed
intermittent starting issues
Thanks, haven't tried that.
Old Dec 16, 2017 | 09:43 AM
vjsimone's Avatar
vjsimone
It's just a quick test for a fuel delivery check.
Open the throttle a bit while giving it a squirt.
With all your fuel system replaced parts (except Injectors), you wouldn't think fuel is an issue.
Old Dec 16, 2017 | 09:54 AM
vjsimone's Avatar
vjsimone
Another thing to try is giving partial throttle (barely open), in the case your AIR Bypass Valve is not opening during your restart. This will allow a little more air into the intake.
runner
23
May 18, 2019 08:44 PM
jerrdan98
May 2, 2017 09:32 AM
AppleTech
Jan 6, 2012 10:39 PM
roninkmg
Dec 24, 2009 09:56 AM
87 4x4 flaresides
Sep 28, 2004 08:13 PM
