Hard shifting
Old Dec 14, 2017 | 08:53 PM
Lakeworthja's Avatar
Lakeworthja
Hard shifting
I have a 2017 F250 6.7 DPF and EGR Deleted with 5” Pro Flow, S&B Cold Air, and ez lynk tuner (GDP). After a month or so the trans started shifting really hard between 3rd and 4th. Anyone else having the same issue or know why?
Old Dec 14, 2017 | 09:47 PM
valleyskipper805's Avatar
valleyskipper805
Most likely its the trans slipping. In a previous truck I had it would slip from first to second gear and I put some of that seal swell stuff in it and it did do the trick for a bit but the slipping came back in the end
Old Dec 14, 2017 | 10:07 PM
Lakeworthja
Hard Shifting
It doesn’t seem like its slipping just shifting really quick and hard?
Old Dec 14, 2017 | 10:48 PM
falconetti's Avatar
falconetti
contact tuner if it has trans tunes.
Old Dec 15, 2017 | 07:27 AM
cangim's Avatar
cangim
Is this when cold only or all the time it does this? Cold only, I recall a thread where they reset the trans table (reloaded?) to make it relearn. once in a while when cold mine has a hard lock for TC on 4th and 5th. Only time noticed is typically when I leave for work, get on main road and very light throttle, if there is traffic to get moving with, I don't notice it.
Old Dec 15, 2017 | 08:32 AM
UP_There's Avatar
UP_There
Definitely sounds like the tunes. I'd contact them right away, before it causes any expensive damage. Ford isn't going to warranty anything with aftermarket tunes controlling the tranny.
Old Dec 21, 2017 | 07:56 PM
Lakeworthja
I’ve learned its called “Shift Defueling” and is common with some trucks with tuning. More prominent in trucks with over size tires. Has to do with the tranny not knowing how to deal with the added power so it cuts the fuel to the motor while shifting which is what causes the dead spot and then hard shift. I’ve looked it up and seems to be a common issue. The tuners are waiting for the firmware to be updated so they can make adjustments to the transmission to correct it. Fingers are crossed. Plan B by a bullet proof tranny and add more power )).
NCMillwright
2009 - 2014 F150
Aug 1, 2018 08:17 PM
SultanGris
6.7L Power Stroke Diesel
26
May 23, 2015 01:34 AM
98infinity
Nov 25, 2013 04:31 AM
OffRoadFord
1997 - 2003 F150
21
Jul 11, 2007 07:41 AM
