LED front head light bulbs
Old Mar 20, 2018 | 12:26 AM
Skip1970's Avatar
Skip1970
i just installed my lasfit 9004s leds in my 89 wow what a difference, wish the highbeam was a bigger difference but its still unbelievable what light these put out.
Old Mar 20, 2018 | 12:57 AM
mebe2k's Avatar
mebe2k
Your alternator and headlight switch are thanking you right now..the LED'S draw way less power than the old halogens..I noticed this on my 87...
I also noticed there isn't much of a difference high beam vs. low beam..but when you're really out in the dark the high beam is a bit more noticeable...
Old Mar 20, 2018 | 08:17 AM
KodiakF250's Avatar
KodiakF250
If you don't see much difference between the high beam and low beam, I have to wonder if you are blinding oncoming drivers with the low beam. We've all seen cars with bright white LED headlights that the owner either didn't adjust the aim or the new lamps throw light too widely instead of in a beam. I suspect some drivers don't realize their new headlights are doing this.
Old Mar 28, 2018 | 11:49 AM
Frank1298's Avatar
Frank1298
I have the Lasfit Led headlights in my 2011 I do need to adjust the height on my lights the output on them is great just wish I was able to adjust the beam pattern on them.
powerstroker02
Jan 11, 2018 10:40 PM
Walwal44
Mar 20, 2014 08:14 AM
whporwil
Aug 30, 2009 06:34 PM
gunnertom
May 23, 2009 04:41 PM
01lariatcrew
1997 - 2003 F150
Feb 10, 2006 04:44 PM
