Sponsored by: Auxito
Squeaking noise?
Old Sep 12, 2003 | 05:52 PM
ItsReallyDarren's Avatar
ItsReallyDarren
Squeaking noise?
I have a 03' F-150 regular cab 2X4 with a 4.6 (stock)
Lately Ive been hearing a sqeaking sound whenever I apply the brakes around 35-45 mph. The sound seems to come from the rear of underside of the truck, but most passengers say its comming from the rear right corner. The sound is like a single bird chriping very fast.
I have no idea what is causing this, the problem started a week ago as I was driving back from the ford fun sunday.
Any ideas?
Old Sep 12, 2003 | 09:03 PM
Racerguy's Avatar
Racerguy
Squeaking noise?
How many miles on your truck?
It's probably something simple like a squeeky brake pad and a slightly warped rotor.
Old Sep 12, 2003 | 10:22 PM
LxMan1's Avatar
LxMan1
Squeaking noise?
What is the average lifespan of the brakes on these trucks? My rear ones have started to squeak at low speeds occasionally, especially in the drive thru!!
Jimmy
Old Sep 13, 2003 | 01:35 AM
ItsReallyDarren
Squeaking noise?
Its still fairly new, only 7,000 miles on it.
Old Sep 13, 2003 | 08:55 PM
CPerry's Avatar
CPerry
Squeaking noise?
Mine did the same thing. It turned out to be coming from the rear leaf spring. A little white lithium grease sprayed on stopped it.
Old Sep 13, 2003 | 09:11 PM
Racerguy's Avatar
Racerguy
Squeaking noise?
Since it only has 7000 miles on it you should take it back to your dealer and get them to fix it for you under warranty.
Old Sep 13, 2003 | 11:57 PM
ItsReallyDarren
Squeaking noise?
Whats odd is that the sound is gone now. For some reason as I was driving today I didnt hear any sqeaks as I pressed the brakes.
Ill keep driving it and see if I can hear anything else.
this problem is a confusing one
Old Sep 14, 2003 | 06:08 PM
ItsReallyDarren
Squeaking noise?
On what part of the leaf spring do you apply it?
Old Sep 21, 2003 | 01:27 PM
true4.2's Avatar
true4.2
Squeaking noise?
You just need to take that mouse off the wheel by your brakes. You're running him too hard! Give him some water, and your problem is solved.
