Transmission hump
Old Sep 12, 2003 | 05:28 PM
Obtuse1's Avatar
Obtuse1
Question Transmission hump
I am ordering carpet for my truck. In order to complete my order I have to tell them if I have a high or low tunnel.
I have no idea how to tell the difference between a high or low tunnel.
Could somebody help me out here.
1979 f-150
reg. cab 2wd
460/c-6
Old Sep 12, 2003 | 05:38 PM
tellico racing's Avatar
tellico racing
Transmission hump
I didn't know there was a difference. Did you check the online store here? I know there are carpet kits specifically designed for your truck....I have seen them on ebay before too.
Old Sep 12, 2003 | 08:15 PM
les nessman's Avatar
les nessman
Transmission hump
You should have a low tunnel as high tunnels were used for 4 speed manuals and 4WD. hope this helps.
Old Sep 12, 2003 | 09:26 PM
Obtuse1's Avatar
Obtuse1
Transmission hump
I also thought a hight tunnel was only used for 4 speed manuals, but it was after I told them that it was a c-6 that they said they had to know if it was a high or low tunnel.
Years ago I had a 74 f-150 that the top of the tunnel was removable, I wonder if that is what determines a high or low tunnel???
I apreciate the replys so far.
Old Sep 12, 2003 | 09:54 PM
ecarter50's Avatar
ecarter50
Transmission hump
Yes if it has a bolt on cover about 2" high it is high tunnel. Your 79 should be low tunnel. The only 2wd c6 trucks with high tunnel I have seen were 75-earlier.
Old Sep 12, 2003 | 11:56 PM
Torque1st's Avatar
Torque1st
Posting Legend
Transmission hump
Peek under the existing carpet and see if you have a bolt on cover over the trans hump. The cover is about 1' wide x 2' long.
Old Sep 13, 2003 | 03:30 AM
neverenough's Avatar
neverenough
Transmission hump
I just bought a truck just like yours last week for parts. I'll look this morning, before I leave, and give you the scoop on it.
Old Sep 13, 2003 | 08:34 AM
neverenough
Transmission hump
Confirmed! You have the low cover on yours.
Old Sep 13, 2003 | 10:04 AM
Obtuse1's Avatar
Obtuse1
Transmission hump
I appreciate all the help! Now I can go ahead and finish my order.
It's not too often I need to ask questions on this site, but it sure is a life saver when I need it.
Thanks,
John
Old Sep 13, 2003 | 04:22 PM
Torque1st's Avatar
Torque1st
Posting Legend
Transmission hump
That is what we are here for!
billgrant
Jan 23, 2014 08:50 PM
fasthauler
Oct 8, 2012 07:53 AM
phampton428
Jan 26, 2011 09:11 PM
MattTheCLGuy
Feb 14, 2008 08:53 PM
Diesel Digger
Dec 7, 2005 08:05 PM
