1985 F150 Bullnose Project - CV Swap - 4.6
Old 11-26-2022, 12:10 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,129 Likes on 1,813 Posts
I dont know what dash he is using the trucks or the CV as I dont remember now.
I did not think VA made a kit for our trucks so it has to be a custom install.
Never mind I see he used a Gen II VA heat / cooling kit
Dave ----
  #152
Old 11-29-2022, 09:21 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
I have cleaned out my inbox. sorry.
I am using the truck dash and made all my own brackets, but it does fit nice and flush. It may be mounted a little higher than the factory unit.
  #153
Old 11-29-2022, 11:00 AM
Olds64's Avatar
Olds64
Olds64 is online now
Beautiful truck. That's quite an ambitious project. I've dreamed about a similar swap. Thanks for sharing.
  #154
Old 01-09-2023, 10:40 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Dakota Digital GSS-3000 Install
We completed the install of the GSS-3000: Universal Gear Shift Sending Unit (dakotadigital.com) for the Gauges we used in this truck. Using newer gauges, with the transmission from the donor car (4R75), we needed something to adapt. This little sending unit/control box is pretty slick and does the hard work, but installing it on the transmission is up to you. The kit is pretty complete, but you need to take the universal brackets and make something that will work for your application. This is just a quick writeup of how we did this in hopes it will help someone doing something similar.
The kit comes with several brackets, so we took the one that mounts the 'sender' and drilled an additional hole in it so that we could use some existing bosses on the transmission. It is also not at a 90 degree bend, so we bent it to 90 so that it would line up better.
Bosses on transmission.
Dakota bracket with additional hole drilled it. We also cut off the original hole.
Here we mounted the longer arm on the sending unit and mounted it to the bracket after bending it to 90 degrees.
Mounted on the transmission with arm on facing the transmission.
We took another bracket that was in the kit and cut it down and drilled for the bracket that would mount on the transmission linkage.
Here it is mounted to the stock linkage. You will have to use some small hardware to mount. These are actually servo mount hardware from an RC car.
Here it is linked up to the sending unit. This is in Park and as you go through the gears, the linkage pulls towards the left.
This sending unit has 3 wires that go back to another box that is mounted inside the cab, and then that unit wires up to the VHX control box. From there you just need to go through the programming of the GSS unit. It also has a neutral safety switch built in and outputs for reverse lights if needed. This transmission provides the NSS and the reverse light output, so we only wired up the sending unit, the 1-wire control, power and ground.
The following users liked this post:
  #155
Old 03-06-2023, 08:36 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Me and my 10 year old went to our first Cars and Coffee event and took the '85. There was everything from Ruckus scooters to Lamborghini's and Ferrari's and everything in between. Had a good turnout. Then we went on a cruise and had lunch.
  #156
Old 03-06-2023, 03:11 PM
FuzzFace2's Avatar
FuzzFace2
Cool that you were able to get the truck out with your son and spend time with each other.
I also went to a cruise in Saturday, there was a pretty good turn out at it also.
I know there was a Lotus parked 2 slots over from me.
I did not get to walk around much to see all the cars & trucks
Dave ----
  #157
Old 04-03-2023, 09:50 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
Had a little Sunday morning drive/photoshoot after our monthly Cars and Coffee.
The following 2 users liked this post by monkey-1:
  #158
Old 04-03-2023, 03:13 PM
FuzzFace2's Avatar
FuzzFace2
Good to see you getting the truck out and enjoying it.
Show here last weekend was called off because of weather.
Dave ----
  #159
Old 04-03-2023, 06:20 PM
moneypit ford's Avatar
moneypit ford
moneypit ford is offline
Great Build and story.
  #160
Old 04-17-2023, 09:25 AM
monkey-1's Avatar
monkey-1
monkey-1 is offline
We had a Team Builder Car Show at work this weekend and my son and I had to take Ruby:
  #161
Old 04-18-2023, 11:06 AM
FuzzFace2's Avatar
FuzzFace2
That is cool 😎
3+ years ago work was 60 years old and put on a show. That was the first time me truck went more than around the block, 40 miles 1 way LOL
Dave ----
old_blue1
174
05-07-2022 07:20 PM
lilorbie
08-03-2018 07:59 AM
Fordtruck51
10-25-2012 11:36 PM
Rokcrln
07-04-2009 10:36 AM
72-F100-4V
18
02-13-2008 08:57 AM
Quick Reply: 1985 F150 Bullnose Project - CV Swap - 4.6
