Quote from Paul Conanski: plug the ports in the back of the heads with 5/8x1" coarse thread bolts with copper washers, and the air pump can stay as an idler or you can remove it and install an idler pulley
I have plugged the back of the heads, 302 engine, i was wondering if i need to plug the inlet & outlet for the pump.I have removed all of the lines except the inlet to the pump.I have plugged the solinoids vaccum lines.Would like to replace it with a idler, but plan on using the pump for a idler for now.Spark plugs work (for now) coarse threads do not work on mine.
thanks
Yeah the shorter belt is probably the better/easier route. As for gutting it, they don't make it easy to break into but not that bad. If I remember correctly there's a couple pins that have to be knocked out and then the internals comes out easily enough with a hammer and chisel.
When I put headers on my 5.8 I deleted the smog pump. I bought a eliminator bracket and pulley from summit. I was cheap enough and that way I can still run the belt it calls for.
I was wondering about the belt. If the original belt will work, i will put a idler pulley on.Mine is a 5.0, idler set up is different, but maybe it will work out.
Some people say yes the tensioner will take up the slack but some say they needed a shorter belt.
You can always get the idler pulley for the non AC bracket it fits the smog bracket and is the same size as the smog pulley
