Oil filtering issues?
Old Dec 11, 2017 | 05:21 PM
Per4mance's Avatar
Per4mance
As some of you recall I had a Motorcraft filter come apart on me in the Ex. Never heard back from Ford either. I've been dumping the oil regularly and it's black as the ace of spades. The filter looks clean which has thrown me for a loop. I wonder if anything might be stuck and holding it in bypass mode. I'd hate to have to pull the housing for the cooler to find out. What do ya think?
Old Dec 11, 2017 | 05:27 PM
mustang_309's Avatar
mustang_309
The filter by-pass has to be stuck open.
Old Dec 11, 2017 | 05:37 PM
Per4mance's Avatar
Per4mance
Yep I thought the same.I just got a bad feeling about this that I'm gonna have to take a bunch of stuff apart in the cold.......did I mention I hat e the cold?
Old Dec 11, 2017 | 06:50 PM
TooManyToys.'s Avatar
TooManyToys.
I hear ya. I just discovered I’ll be changing a front bearing in the MDX.
Old Dec 11, 2017 | 09:08 PM
wedge542's Avatar
wedge542
pull the filter,the standpipe,the oil cooler bypass/inlet oil cover,the oil drain, all can be done with just the filter out of the way, that way you have covered everything in the can at one time, ck the standpipe bypass and spring assembly. That bad filter has caused you nightmares no doubt.
Old Dec 11, 2017 | 09:23 PM
Per4mance's Avatar
Per4mance
Ya that was the plan, now to find a warm day or some time at my friends shop.
Old Dec 11, 2017 | 09:28 PM
wedge542's Avatar
wedge542
Did you ever change out the oil cooler bypass spring when you replaced the plunger valve?
Old Dec 11, 2017 | 10:11 PM
Per4mance's Avatar
Per4mance
Never did that to this truck
Kurtboyd
Aug 28, 2013 12:23 PM
GTRider
Aug 11, 2013 05:49 PM
05 f250 6 inch lift
Sep 25, 2012 08:20 PM
allisonmo2
Feb 23, 2009 06:22 AM
fordsrgrt
Oil & Lubrication
May 9, 2006 05:34 AM
