Cat Scale Weight
Old Dec 10, 2017 | 05:25 PM
ksteve06's Avatar
ksteve06
Cat Scale Weight
Do you think I need to transfer more weight to the front axle? Truck and trailer near perfectly level. Truck is 2017 F350 CCSB 6.7 and Trailer is 31 ft Airstream, 10000 gvwr
Equalizer hitch with 5 washers.
Truck only
Steer axle 5000
Drive axle 3680
WDH not engaged bars in bed of truck
Steer axle 4560
Drive axle 5120
Trailer axle 7900
WDH engaged
Steer axle 4720
Drive axle 4920
Trailer axle 7960
Old Dec 10, 2017 | 09:00 PM
Robb81's Avatar
Robb81
If it's level you're good.
Level is the goal not a certain percentage on the front axle.
Old Dec 10, 2017 | 11:49 PM
DeputyDiesel's Avatar
DeputyDiesel
Thanks for the numbers! I was wondering the scale weight of the front of a 350 6.7 because I found a cool equation for determining proper tire pressure.
Old Dec 11, 2017 | 06:37 AM
Redrockerstl55's Avatar
Redrockerstl55
I would say you are good to go. You have shifted the balance when the trailer is attached by 400 lbs with the bars attached. That’s almost 10% more weight on the front axle helping even the weight, create safer steering situations (expansion joints, major potholes and sway).
That 6.7 really helps even out this weight. Would love to see the numbers with this same trailer hooked up to a gasser.
Thanks for posting the numbers.
DelawareDead
All Things Towing
Feb 27, 2019 02:38 PM
Travelchief
All Things Towing
Sep 22, 2017 12:09 PM
tmont
All Things Towing
38
May 24, 2016 06:50 PM
FatOldGuy
Dec 18, 2015 10:35 AM
rattleNsmoke
All Things Towing
Oct 10, 2011 06:09 PM
