Transmission swap
Old Dec 9, 2017 | 08:18 PM
TurboTuff's Avatar
TurboTuff
Transmission swap
Will an E4OD from a 1996 F350 4x4 7.3 fit a 1994 F250 turbo Diesel 4x4 7.3?
Old Dec 9, 2017 | 08:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, except for two issues. One, the newer torque converter has six studs where the older one has four. Second, There was a change to some diodes in the PCM and solenoid body. You'll need to do some research on that because I can't remember the details. It may work as is, I just can't remember. But both the torque converter and solenoid body could be swapped from the old trans if they are in good shape.
Old Dec 9, 2017 | 09:09 PM
TurboTuff's Avatar
TurboTuff
Ok I'll do that.
Does the fact that the '94 is IDI and the '96 is PowerStroke create any issues?
Edit: BTW they are both 4x4
Old Dec 10, 2017 | 07:43 PM
Mark Kovalsky
I covered the issues above. There are no other issues.
Ford_Six
Ford Truck Parts for Sale
Apr 2, 2017 12:36 AM
blue oval outlaw
Jun 22, 2014 09:58 AM
Bigdaddybendog
May 28, 2010 01:31 AM
HardScrabble
Nov 30, 2008 11:02 AM
