Random long crank
Random long crank
Looking for possible causes of a long crank situation I'm having with my 06 f350 6.0 diesel. The long crank situation seems to happen most often when cold. If I keep it plugged in over night it usually starts normal. After it is warmed up it seems to start normal but if it sets for several hours without being plugged in the long crank situation seems worse. Any suggestions?
Could be several things. Post this in the 6.0 forum to get more expert eyes on it. They will get you fixed up in no time
https://www.ford-trucks.com/forums/forum107/
Apparently, the GPR problem can be erratic and not happen all of the time. Mine is worse when not plugged in and the ambient temps are 32*F or below. If the GPR does not kick in, mine cranks for a long time, it takes several attempts to start it and there is lots of white smoke (meaning unburnt fuel going out the exhaust).
You can search for my thread on this issue. I have purchased the heavy duty GPR from diessel-o-rings and when I have a chance, I will replace the existing one (which I think is the original) with the new, larger, HD one.
Hope this helps and good luck chasing it down..
Kingkong0192
13
Aug 20, 2016 03:52 PM
hedhntr
Mar 20, 2010 08:22 PM
KrenzyRyan
52
Jan 13, 2008 09:34 PM
unburnt diesel)
