Inside Back Up Senor Replacement?
Old Dec 8, 2017 | 03:54 PM
efiguero's Avatar
efiguero
Hello everyone, using the tech folder I was able to troubleshoot my back up sensor issue and was able to identify the faulty senor. It is one of the inside sensors. After getting under the rear bumper to investigate, it seems my tow hitch is hindering access to the sensor. I can touch it but don't have much room to pull the clips in order to remove it. Anyone have a suggestion on doing this? I assume I could remove the hitch which I would rather not do, removing the rear bumper seems like it might be easier than the hitch or I could be wrong. Any suggestions?
Thanks
Elliott
2003 Excursion 2WD 6.0
Old Dec 8, 2017 | 05:15 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Elliott, there are tabs on either side of the sensor. They are very flimsy and weak. Pull each of them back away from the sensor, and then push the sensor in from the outside of the bumper. Easy Peasy Lemon Squeezy.
Old Dec 8, 2017 | 05:19 PM
efiguero's Avatar
efiguero
Yeah the thing is I don't have room, I can squeeze my hand in there and barely touch it, but not much else. I will try again to see if I can get to the tabs some how, but couldn't on my first try. I read in one of the threads about replacing these that someone had a tow package that was in the way as well and that they could not reach it so I wondered if someone had any other ideas. Anyhow, thanks for the response! By the way did you enjoy the quick snow storm last night? It was pretty cool!
Old Dec 8, 2017 | 05:49 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yeah, the kids loved it today. We got 3-4 inches in Bastrop.
Old Dec 8, 2017 | 06:52 PM
jspence105's Avatar
jspence105
You got snow......we still haven't had any here.
Old Dec 8, 2017 | 11:36 PM
RBerry9511's Avatar
RBerry9511
Thanks
Elliott
if you pull the rear license plate you should be able to reach in there no prblem.
Old Dec 10, 2017 | 07:02 PM
efiguero's Avatar
efiguero
Ahh good idea! See that’s why I like this forum! I did have a buddy with a smaller hand that was able to reach it too. I guess my hand and arm are too fat. Lol
lindenj
Dec 16, 2016 02:01 PM
Geeeyejo
Sep 29, 2014 08:13 PM
cycle27
Sep 19, 2008 03:24 PM
Mattias
Jul 26, 2002 12:24 PM
