4x4 econoline build
4x4 econoline build
So this has probably been covered under other topics but Ill try this anyway. Bare with me might be a little long. I currently have 3 vans and possibly picking a 4th one up this weekend. 2000 E350 cargo 7.3 diesel, 2003 E250 cargo 4.6, 2005 pax van with 5.4 all power options, 2007 pax van 5.4 all power options. So ultimately Im wanting a 7.3 4x4 with power windows and locks. Doesn't really matter to me cargo or with windows. So here is the question. Would it be easier to convert manual to power windows and locks or convert gas to diesel? Either way I would have all the wiring, brackets, etc and once I start the build Im doing body off frame and building it up right with powder coating and painting. Ive read some people having problems going from manual windows to power. So pick the best body and build from there? Take the one that has the most of what I want and add to that?
Whats a pax van?
I believe the regulator and lock assembly is riveted on, which is no big deal, knock the rivet mandrel thru with a punch and drill out the rivets. They're aluminum so it's painless. You will need one of those big rivet tools to reinstall. You could bolt everything in but it would be difficult because of access, if I recall correctly.
Alice's .:Project Yuki:. | 08-15 Ford E350 Extended Passenger Van (Preferably a Power Stroke Diesel)
AliceSML79
Projects
02-04-2017 01:47 AM
