2009 F550 6.4 Wont Start
Thanks In advance
First Post Seem to be to a Doosey
2009 F550 6.4 Wont Start Bucket truck
My Tech drives the truck for service and went into Limp mode several times He kept resetting the codes with a scanner to keep the truck going . Until the truck would crank ,but would not start. He did not write codes down and must have resetting 10 times without letting me know.
The truck was towed to a shop close to where he broke down. I could not give them codes they said they could not get the truck started. He brought in a Ford Tech who flashed computer. He said he could only get it started with either. After the flash I am not sure if he was telling the truth
He said the High pressure pump failed. 5100.00 job
I towed the truck to my mechanic. He said the Lift pump was out putting 2 psi. The filter was rusty and shaving in the lift pump. What I found out was my tech was running the fuel low a lot.
He Replaced lift pump and was getting 7psi. Fuel flowing great on top of the motor. Still would not start. He said he is getting 5000 psi He than thought the high pressure pump was bad and found fuel under the truck . Said high pressure pump is working. Injectors were pumping.
Checked fuse 72 actuator working fine. Pulled side of motor says crank and cam are working,however not sure if they are bent etc.
He is not sure what to do at this point.I think he is an honest guy. And trying not to rip the motor apart.
Has anyone had this experience or any suggestion would be greatly appreciated
I hope you do not have a failed HPFP accompanied by metal particles in both filters....
understand that the fuel system is tightly coupled and when the HPFP fails, it causes problems with injectors as well.
metal in filters means the HPFP is failing or has failed. when this occurs, metal particles enter the fuel system.
the HPFP pumps fuel to the fuel rails, the fuel rails feed the injectors, unused high pressure fuel returns back to the fuel system. this is why metal particles from the HPFP wind up in filters.
these particles that travel from the failing HPFP to the fuel rail, then the injectors, will get stuck in the injectors causing the injectors to fail as well.
once it is established that the HPFP failed, and there is metal from the pump in the fuel system, the repair has to be complete...or things will fail again.
a worst case senerio
replace HPFP
replace injectors
replace fuel lines from fuel lines to injectors
remove fuel rail and inspect for metal particles, if found replace the fuel rails
back flush the fuel lines from front to back
replace all filters
remove the tank, inspect for metal particles, flush the tank
replace HPFP
replace injectors
replace all filters
2009 6.4l Wont Start
Thank you I am going to go over this with the mechanic we are working together on this at this point.
There was rust particles in the lift pump which came directly from the fuel tank i thought.
I do not believe there was any metal particles in the fuel filter on top where the lift pump pumps to
2009 F550
Is there any situation were no codes can be present and the truck go into limp mode and than not start at all
Now the truck cranks does not start . Fuel System seems to operating as it should but truck will not start.
Could the erg fail and not code and lock out the truck from starting
Respectfully, Obviously your truck is in the wild where you might be unaware of everything that has and has not been done to it.
IF by chance, someone used starting fluid on this motor then your entire valve train could be toast. You might have them pull the glow plugs so they can do a compression test.
Good luck
Good luck
I hear you Sometimes I feel like Im in the sticks However I am in New York In Long Island
Went to a new guy and I didn't like to hear they sprayed ether. What I get from listening to a friend recommendation
Is there any way to definitely tell if ether did the truck in
There is fuel when pulled the glow plugs The only thing left is compression
Any advice anyone can pass along would be appreciated. Learning diesel the hard way
This is getting worst
Compression can be check via the glow plug port.
Also, remove the oil filler cap and then place your hand on the open oil filler hole while cranking the motor (glow plugs in place) - significant flutter could indicate a collapsed piston. Though your best approach is simply pull the glow plugs for a compression test.
Good luck.
Here an update. Do not know what to do hands up.
Fuel system seems to be working as it should. Still no start compression on the two rear cylinders we can reach 250. Mechanc stated compression low however he thinks it might be do to timing.
he is suggesting to go to another mechanic that he had in to look
im sure his bill will be a 1000 ++ with the lift pump install and unsuccessful fix.
first guy 500 tried to sell me high pressure pump job for 5100. Until 2 Nd guy replaced lift pump
short of Ford to pay top dollar. Im going to try to search out a ford 6.4 guy
anyo e have any diagnostic help.
This is a great resource:
Powerstroke 6.4L Bible Page
If you look at page 16 of the Overview you’ll see that the crank to cam timing is a direct gear drive, not likely that it could jump.
But, that leaves two sensors that could be causing problems - cam position sensor and crank position sensor. They have to synchronize before the motor will come to life. Which leaves the sensors themselves or the potential of a bad connection or chaffed wiring harness that is preventing the computers from communicating.
Scratching my head as in an earlier post I thought you mentioned you had fuel, does that mean fuel in the cylinder?
