hav24wheel’s 99 E350 4x4 swap
So, with how life has ended up, I’ve got myself a situation with needing more room than my Pickup can supply for longer road trips. So I drove a couple states away and picked up a rust free, and what was suppose to be clean and only a couple dents. Well it has a lot of dents, but I couldn’t pass up the price. I started off with the front axle swap, next up will be the trans/t-case/gas tank. It’s a V10, has a 4 inch lift as it sits and 35s. Gutted the interior, resealed Windows, put new carpet in it, did a tune up, fixed broken exhaust manifold studs so far. It’s sitting about 115,000 miles. Here’s some pics of what I’ve got done so far.
Here it is all stock and on stands waiting to start the swap.
05 F350 front axle set in place
Custom radius arm bracket
F350 coil springs and Excursion shocks
Trac bar bracket,van steering mated up with the Superduty steering
99-04 Superduty grill guard made to fit.
There’s more to come as time goes on....
He’s it on jack stands all stock right b4 the swap started.
Unjoint has a leaf and a coil kit, but I’m WAY TO CHEAP to spend that much on a kit!! The one thing I might order from them is the stuff to shorten the gas tank. I have to make adaptors to hook the Superduty axle to the van sway bar yet too... Another thing I don’t like about kits is you can’t push the front axle forward as much as I like. I’m running 35s on a 4 inch everything I’ve seen you need a 6 inch for 35s.
Ya, I hear ya, it had 265s on it when I got it and they rubbed horribly bad. Thes 35s only rub a little bit with the wheel turned and hit a bump just right. I’ve pushed the axle forward on a few vehicles to clear bigger tires easier, like my pickup I’m running 38s on a 6 inch lift and the tires don’t touch the fenders at all.
Hers a bunch of random pics from the last couple days of work.. had to cut down the gas tank for tcase clearance, mod the crossmember, the shift cable bracket, and have yet to do the tcase shifter. But I got it driving again. Had to redo the drivers side exhaust because it wouldn’t fit, or let a front driveshaft be installed.
I just ran across your '79 4x4 Build. Very cool. Looks like you went leaf-sprung on that one. I have pipe-dreams of doing something like this with my '85 maybe someday, but with a coil-spring front if at all possible. Nice work. Cotton
