no start after rebuild???
Old Sep 12, 2003 | 08:45 AM
CrazyFordMan's Avatar
CrazyFordMan
Unhappy no start after rebuild???
i just got my engine back in the truck after rebuilding it and it wont start. it will fire but wont start. i have had the distributer in every way imaginable and i took the front cover off to make sure i had the timing marks lined up and everything is good. is there anything that could be causing this like manifold leak or vacume leak??. here is what i did to the engine
bored .30
new pistons
mild head port
new cam (crane p/n 443901)
and took the air pump junk off
any ideas would be appreciated
Old Sep 12, 2003 | 08:10 PM
CrazyFordMan
ttt
Old Sep 12, 2003 | 09:06 PM
CrazyFordMan
anyone???? please im desprate
Old Sep 13, 2003 | 08:33 AM
CrazyFordMan
ttt
Old Sep 13, 2003 | 06:51 PM
CrazyFordMan
ttt
Old Sep 13, 2003 | 08:16 PM
Trail Rider II's Avatar
Trail Rider II
Fuel pressure? DId you check the valve using a nail punch? it looks like a tire valve. You should get a bit of fuel out of it.
Recheck all electrical connections.
Take number 1 cly. to top dead center compression stroke. Check your distributor that its firing correctly synced. with the crank and TDC.
Get a code reader and see if there are any faults. $24.95 at Wally World.
Old Sep 13, 2003 | 08:49 PM
CrazyFordMan
ya i pushed the valve and there is fuel there. i got the timing right i checked it with a light when cranking. will it throw a code even tho it hasent started yet???
Old Sep 13, 2003 | 09:22 PM
CrazyFordMan
nope no codes
Old Sep 14, 2003 | 02:45 AM
90f150moneypit's Avatar
90f150moneypit
What's your valvetrain consist of?
I just converted to adjustable valvetrain and when I adjusted the valves the lifters were apparently bled down from sitting so long. This caused the valves to be adjusted way too tight leaving the valves open and not creating enough compression to start it. I verified this with a compression check. Only checked two cylinders, one was at 85psi the other at 0. I had 120psi across the board just before the change (literally).
If I were you I would look into this as a possibility.
Old Sep 14, 2003 | 10:26 AM
CrazyFordMan
i still got stock valve train and all the lifters are brand new
Old Sep 14, 2003 | 07:28 PM
CrazyFordMan
ttt
Old Sep 14, 2003 | 10:19 PM
Trail Rider II
Ok, I am confused, reread the post. You said its getting fire and fuel, if your distributor is not out of time, the vavles are adjusted right, there is nothing to stop it from running.
Check your firing order for year and engine. Check the distributor guttttts. Coil. and ECM.
Other than that maybe its the fuel pump. My Dads 87, would not start turned out the fuel pumps and a clogged fliter. were the culprits.
Get your HAYNES BOOK out and double check.
Old Sep 14, 2003 | 10:26 PM
stepman's Avatar
stepman
I'm confused too . Do you get at least a backfire or something, anything?
Old Sep 14, 2003 | 10:43 PM
CrazyFordMan
it will backfire thru the TB like it out of time but its not. unless the balancer i got from the wreckers has the timing marks in the wrong spots even tho its from a EFI 351
Old Sep 14, 2003 | 10:56 PM
stepman's Avatar
stepman
O.K. timing WAY early hav you tried backing it up? Ignore the marks on the crank for now.
