Need Error Code Help.........
Old Oct 24, 2001 | 10:00 PM
slowsix's Avatar
slowsix
Old Oct 25, 2001 | 04:14 PM
brett_d's Avatar
brett_d
I just performed a KOEO test on my 1988 ford 5.0. I recieved the error code of 85 when testing the continuous memory. My book says that it is a "Canister Purge Circuit Error". What is this and how do I fix it????
PS I just completed the Mass Air Conversion yesterday and installed the new computer. The instructions also said that I had to disconnect the MAP sensor line and plug the intake hole. The MAP sensor is left open to the atmosphere.
Thank you all for your help through my project.....
1988 Ford F250 4x4, 5.0 liter (soon to be Roller 5.0), Mass Air Conversion, Rebuilt AOD tranny, 2.5 Dual exhaust, Headman Shortyheaders, 33" BFG's Mud Terrain, 4.11 gears.
1980 Ford F100, with 1988 5.0L Roller (carburated), T-5 five speed Borg Warner World Class Transmission, 31 spline 9" 3.73 posi , and a bunch more!! 13.78 quarter mile.
Old Oct 28, 2001 | 12:43 PM
PAUL_2's Avatar
PAUL_2
Locate the charcoal cannister & follow its vacuum line until it connects to the canister purge valve , check that the vacuum lines to & from the valve are connected & that the purge valves electrical connection is secure . You may have disconnected its vac lines or electrical conection by accident while doing the Maf work .
