Sponsored by: Real Truck
Shocks
Old Dec 4, 2017 | 05:15 PM
brian42's Avatar
brian42
Veteran: Navy
That's why it's called a steering damper and not a steering fixer.
Sorry, I couldn't help myself.
Old Dec 4, 2017 | 05:34 PM
geekwithoutacause's Avatar
geekwithoutacause
lol. I hear you. So many people throw money at a new damper only to conclude after install the symptoms are the same.
Ball joints are a good thing to inspect. Should be tested under full weight.
Old Dec 5, 2017 | 09:17 AM
brian42's Avatar
brian42
Veteran: Navy
I usually spend $30-$50 for a decent damper. I do a lot of off-roading so I go through them a little faster than most so I don't need the Mercedes of dampers. As long as it does it's job I'm good with it since replace it about every other year.
Old Dec 5, 2017 | 09:43 AM
Mike1's Avatar
Mike1
how do you know if your dampener I'd bad? Mine looks own but it's not leaking, bent or rusted.
Old Dec 5, 2017 | 09:45 AM
Mike1's Avatar
Mike1
Originally Posted by geekwithoutacause
I use Bilsteins. Pretty firm but they work well.
A steering damper won't fix anything. It just disguises an issue elsewhere.
How are the trackbar bushings.?
all the bushings are in great shape and just had the ball joints and front joints replaced with new hub assemblies, maybe 500 miles on them now.
Old Dec 5, 2017 | 10:29 AM
geekwithoutacause
You probably had an alignment done.
The steering box is another item that wears out quickly. Faulty balljoints can make the steering box to work harder causing it to wear out. Many people complain about the steering boxes (I'm sure they are not the greatest) but the root cause is the balljoints.
Check for slop in the steering. Switch engine off and see how far the steering wheel turns without any movement in the steering bar. Look on Youtube for examples. Some are quite bad. Redhead steering boxes are a popular replacement.
Old Dec 5, 2017 | 01:39 PM
brian42's Avatar
brian42
Veteran: Navy
My steering gets a little twitchy. When my damper gets tired the truck wants to follow ruts and grooves more than usual and that puts more strain on the steering box to do the work. I haven't had a damper leak either. It usually gets beat up enough that it loses its luster.
Old Dec 5, 2017 | 01:52 PM
geekwithoutacause
My steering gets a little twitchy. When my damper gets tired the truck wants to follow ruts a grooves more than usual and that puts more strain on the steering box to do the work. I haven't had a damper leak either. It usually gets beat up enough that it loses its luster.
A steering damper is supposed to limit the impact of sudden forces on the steering. Hitting a pothole is one. It limits the steering from jerking all over the place.
I guess to test it you need to take it off and see if it resists moving in and out. If there is little to no resistance it is shot.
Old Dec 11, 2017 | 09:32 AM
Mike1's Avatar
Mike1
Getting colder out now, so everything is tightening up a little bit. I noticed the other day, standing outside the truck and reaching through the window, that while the truck is running, I can move the steering wheel about 1.5" - 2" before the Pittman arm starts to move. Should I check the joint on the steering shaft or would this be play in the steering box?
Old Dec 11, 2017 | 09:37 AM
Copper.Farm's Avatar
Copper.Farm
Time for a new steering box.
Old Dec 11, 2017 | 10:24 AM
geekwithoutacause
This would be the steering box. This is a VERY common issue.
Old Dec 11, 2017 | 10:49 AM
Mike1's Avatar
Mike1
I guess I'll have another $600 - $800 into the truck and some lost skin, come spring time, haven't even addressed the door skins, rockers or cab corner rust yet...LOL
78bigbronco
Dec 12, 2019 05:57 AM
dogswife1969
Dec 22, 2015 10:18 AM
t_lcohen
1997 - 2003 F150
Oct 1, 2006 01:09 PM
wmcutter
All Things Towing
Jul 22, 2005 07:19 AM
EGPD1725
Oct 22, 2004 08:51 AM
