Codes
Old Dec 1, 2017 | 03:12 AM
Irv60's Avatar
Irv60
Codes
1995 Ford E150 Van 5.0 engine 180K miles replaced Idle air control valve, now check engine light comes on after about 10 to 20 minutes driving. Had buddy hook up scan tool getting codes " 311 Thermactor Air System Not Working - Bank 1" and "332 EGR Valve Not Opening (EVP/PFE/Delta Pressure FeedbackEGR (DPFE))". Do anyone have any ideas what wrong and or what needs to be replaced?
Old Dec 2, 2017 | 06:31 AM
subford's Avatar
subford
You did not say if these were KOER or CM codes so.
With the check engine light coming on after about 10 to 20 minutes of driving I will guess that you are talking about a Continuous Memory (CM) DTC 332 code.
Continuous Memory (CM) DTC 332 indicates the EGR valve did not open with the engine stabilized and the EVR solenoid duty cycle present sometime during vehicle operation.
Possible causes:
-- Obstructed or cracked hose to EGR valve.
-- Icing.
-- Damaged EGR valve.
-- Damaged EVR solenoid harness.
But if the 332 was a KOER code then:
DTC 332 in Key On Engine Running (KOER) indicates the EVP sensor input did not change after the EVR solenoid was instructed by the Powertrain Control Module (PCM) to open the EGR valve.
Possible causes:
-- Vacuum hose leaks.
-- Icing.
-- Obstructed vacuum hose.
-- Obstructed EVR solenoid filter.
-- Damaged EVR solenoid.
-- Damaged EVP sensor.
You do not have the Delta Pressure Feedback EGR, DPFE system.
You have the EVP sensor sending the code.
311 is an KOER code only.
DTCs 311 indicates the Secondary Air Injection system is inoperative.
Possible causes:
-- Vacuum hoses damaged.
-- AIRB/AIRD valve inoperative.
-- Air Pump inoperative.
-- AIRB/AIRD solenoids damaged.
I will also guess that you broke a vacuum line (maybe a red one) while changing the Idle air control valve. This will also cause the 311 & 332 codes.
mandru05
Nov 29, 2018 06:16 PM
RRH_88
May 20, 2016 11:28 AM
cjharvey2000
Mar 8, 2016 10:06 PM
Colt45ws
Dec 24, 2009 10:27 PM
el conquistador
1983 - 2012 Ranger & B-Series
13
Apr 27, 2004 10:53 PM
