Transmission fluid capacity and clutch bleeding info
Hello guys,I have a 1994 f 150 5 od speed . Previous owner tac welded the fill plug and looks like I won't be able to get it loose. So il have to do a "top fill" job on this thing. Since I can't check to see how much fluid I still have in it. I need to know how much fluid it actually hold when has been drained. Been hearing anywhere from 3-4 quarts.does anyone knows the answer to this? And Mehta is best transmission fluid for it?.ALSO I need to bleed the air of the clutch line. Am assuming is as simple as like doing brakes right? Or there more to it? Thanks in advance for any help.
pdt575
1983 - 2012 Ranger & B-Series
04-15-2006 12:47 PM
