Battery Drain Issues
Old Nov 29, 2017 | 09:45 AM
gofiger's Avatar
gofiger
Did a parasitic draw test on my 02 7.3PSD. Tested on driver side battery with ampmeter inline on negative cable. Passenger side battery was still connected Constant 190 ma draw with all fuses and relays removed and alternator and starter disconnected. I then disconnected negative cable on passenger side battery while still leaving the meter on the driver side battery and draw was reduced to 16 ma. Any ideas about this will be greatly appreciated.
Old Nov 29, 2017 | 02:08 PM
Karlow's Avatar
Karlow
after market alarm?
Old Nov 29, 2017 | 02:24 PM
Walleye Hunter's Avatar
Walleye Hunter
What I don't get here is the difference with a battery hooked vs unhooked. That should be the other way around. Have you ruled out a shorted battery on the passenger's side? I had a bad parasitic draw and when all was said and done my alarm/remote start system isn't working and my draw is down to normal levels.
Old Nov 29, 2017 | 06:27 PM
gofiger's Avatar
gofiger
Karlow I do as a matter of fact have a Crimestopper remote start but when I pulled that fuse it made no difference in the amperage draw. Thanks for your input
Old Nov 29, 2017 | 06:39 PM
gofiger's Avatar
gofiger
When doing the test I left the passenger side battery hooked up and tested from the driver side battery. With everything disconnected including the alternator, starter and glow plug relays I was still measuring a 190 ma draw. It was only when I disconnected the passenger side battery that the draw dropped to 16 ma. Could a bad passenger side battery cause a draw on the on the system. One thing to note is that before I tested I charged the batteries but from the drivers battery and not individually. Is it possible that the passenger side battery was drawing from the driver side battery thus showing a load? My electrical troubleshooting skills are not my strongest!! Thanks for your help.......
Old Nov 29, 2017 | 06:46 PM
Colorado350's Avatar
Colorado350
Put your DS battery in the passenger side, see if get the same results. Have you individually load tested your batteries?
Old Nov 29, 2017 | 06:56 PM
gofiger's Avatar
gofiger
I should have done that already but guess what?? I will test them individually tomorrow........... Thanks for your help
Old Nov 29, 2017 | 07:10 PM
pirschwagon's Avatar
pirschwagon
One Battery may not have sufficient Surface Charge or Reserve Capacity thereby drawing the Good Battery down
Old Nov 30, 2017 | 01:00 AM
Rikster-7700's Avatar
Rikster-7700
With such a (relatively) low current draw, it very well could be the batteries trying to equalize out. One may have a slightly lower internal resistance than the other, or have a slightly higher state of charge......
Old Nov 30, 2017 | 05:21 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
If needed, always replace batteries in pairs. Otherwise the weak one will pull down the strong one. Possibly what you are measuring here.
dumptech
16
May 24, 2024 06:50 AM
pauldfixr
Nov 17, 2009 10:35 PM
jroehl
General Automotive Discussion
Sep 8, 2008 10:36 AM
rgbutler
1997 - 2003 F150
Jan 2, 2006 07:25 PM
jaw1959
Electrical Systems/Wiring
Mar 19, 2001 01:15 AM
