1966 - 1977 Early Broncos
Door Hinge
Old 11-27-2017, 01:47 PM
dodmort's Avatar
dodmort
dodmort is offline
Door Hinge
Does anyone know why Ford used the Phillips head bolts on the hinges attached to the door post. They used hex head bolts on the door side but not against the post. There seems to be plenty of room for hex head bolts against the post side of the hinge. I am sure you know i will tear up the Phillips head ones getting them out after 50 yrs.
Old 11-27-2017, 11:22 PM
77&79F250's Avatar
77&79F250
77&79F250 is online now
Received 3,408 Likes on 2,529 Posts
No idea, but lots of PB blaster and soak time. Use a very proper quality grade phillips head bit. Maybe a #3 bit will fit better than a #2.
Wet the bit end and put it in some fine sand or baking power to help get the bit to bite. You do not want to strip them and you really do not want to break them off.
Maybe even have a set of vice grips on the head edge and the bit in to help break it lose.
Old 11-28-2017, 08:10 AM
dodmort's Avatar
dodmort
dodmort is offline
Been soaking them for a couple of weeks....only one came out.these little screws are not very big . It appears that replacement hinges and hardware come with hex head bolts. Not what Ford did. Maybe have to drill !??? Wrong time of year to not have doors in the morning though.
Old 11-28-2017, 08:13 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
heat & impact works as well.
Sometimes I use an old school
impact driver/hammer driven
hand (non ele/pnuematic) tool.
Unsuccessful? (broken off) No worries. A center punch, right size drill, pic to pull out remaining thread pieces in the OD of the 'hole', followed by chasing the threads w/ a right sized tap can perform a great result.
Keep in touch, let us know if this is not what ur askin!
Old 11-28-2017, 11:57 AM
dodmort's Avatar
dodmort
dodmort is offline
Dead on as to what i want to do. Have not tried the heat yet. up for it this afternoon.
Old 11-28-2017, 04:52 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
"...not tried the heat…"
No oxy/acet here @ home so I just use a lill handheld tank w/the cheepo tip (propane?) after a day or so of 'penetrating oil'.
BTW: last X we spoke U sent some pic of the '68M…how's it doin these daze?
Old 11-28-2017, 09:31 PM
dodmort's Avatar
dodmort
dodmort is offline
Success !!!!! One door down.
Lots of Liquid Wrench--little heat from propane torch....big Phillips head driver on end of impact wrench....( saw this done. On Triton s. Plug removal on you tube..so what the heck huh)
M715 is pretty well living at my son in laws. ...3/4 mile from here. So it is close by.
Old 11-29-2017, 04:42 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
second door need help?
AND
Behinf Door Number Two....?
Old 11-30-2017, 08:20 AM
dodmort's Avatar
dodmort
dodmort is offline
All done. Re drilled the old holes on the hinges out to 5/16 and put in hitch pins that size. Now have removable doors. Cost like 12$ for the hitch pins. There is plenty of room to use body bolts on door post and not have to deal with the flush mount Phillips head bolts.
Old 11-30-2017, 09:59 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
removable door
same here. I have some pins w/the wire bail that snaps over to lock/unlock so they don't fall out.
have fun, B safe AND productive!
jim collins
11-24-2022 11:20 PM
2manytickets
05-28-2017 07:02 PM
aaronbauer
01-19-2015 07:31 AM
ryans88gt
01-15-2014 04:51 PM
53rat
03-21-2009 11:51 AM
Quick Reply: Door Hinge
