1988 f150 hi pressure pump problems
Old Nov 24, 2017 | 08:12 PM
BIGEDDIE's Avatar
BIGEDDIE
hi, i have a 1988 F150 4x4,351 W C6 ,short bed ,duel tanks,40k miles,,,it was a plow truck,off the road for 15+ years very nice condition..i got it back on the road in august,,,,replaced the front gas tank and sender and fuel pump,has been running good until last week,started losing power up hills,2 days ago lost a lot of power,started popping thru the throttle body about 2000 rpm,replaced the front fuel filter,no change,checked the plastic duel tank canister ,no filter in it and clean fuel,checked the fuel pressure at the fuel rail,with a gauge read 34 psi ,reved the engine it went down to 20 psi,took it for a ride it went down to 10 psi, installed a new hi pressure pump ,at it will not pump fuel.returned it to auto zone,got a new on it will not pump fuel,i can hear the pump run for about 3 sec, when you turn the key,,,the truck would idle and run on the old pump from both tanks,,,thank you for any help,,,Ed
Old Nov 24, 2017 | 09:31 PM
Eric Fullerton's Avatar
Eric Fullerton
A lot of times the replacement high pressure pumps aren't the same plug as the original, any chance you wired it backwards. The pump will run backwards, just won't pump.
Old Nov 24, 2017 | 09:48 PM
ChRoNo16's Avatar
ChRoNo16
there is a relay hidden on the firewall, sometimes near or behind the brake booster that fails. my dad had the exact same thing happen and we found that relay was bad.
Also check the pressure regulator. that may be bad as well.
Old Nov 25, 2017 | 06:34 AM
subford's Avatar
subford
Sounds like the in-tank pumps are not pumping fuel.
Could be bad in-tank pumps, bad in-tank fuel hose or bad fuel tank selector switch at the dash.
Image showing bad in-tank hose:
Attachment 285947
Old Nov 26, 2017 | 06:14 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Check voltage with pump running (under load). Check it as close to the pump as you can. A voltage drop under load indicates a bad connection at some point.
Check pressure and flow as close to the fuel rail as possible. Pressure and flow are not the same thing.
Quick66
Feb 12, 2017 12:33 AM
chrisjb
Mar 22, 2014 07:06 PM
dustmote
Nov 20, 2011 06:50 AM
dustmote
Nov 19, 2011 03:08 PM
Jtanner76
1978 - 1996 Big Bronco
Jan 13, 2004 09:51 AM
