Bulb install question
Old Nov 24, 2017 | 11:40 AM
2017-350's Avatar
2017-350
Is it possible to replace the high/low beam bulbs without removing the headlight housing? I have a front end replacement bumper and to remove my housing i will have to remove the entire bumper. Im hoping someone cal tell me if i remove the batteries and maybe washer fluid container i can get to it. Thanks
Old Nov 24, 2017 | 11:47 AM
Brandon606's Avatar
Brandon606
Providing its the 6.7, remove air intake on passenger side, remove washer fluid neck and battery on drivers side, then yes you can remove all 4 headlight bulbs. Im not familiar with the 6.2.
Old Nov 24, 2017 | 12:16 PM
2017-350's Avatar
2017-350
Yes, it is the 6.7L
Old Nov 24, 2017 | 12:30 PM
Brandon606's Avatar
Brandon606
The air intake had 1 push pin in front and 2 snaps on each side and it lifts out. Washer bottle neck is press fit so get the push pin loose and one push pin for hose and it comes out. Id advise removing the battery, it gives you much more room. Once you have done this you can access all 4 bulbs. I just did the led swap Wednesday.
Old Nov 24, 2017 | 01:17 PM
Poncho450's Avatar
Poncho450
6.2 also appears to be accessible by unsnapping part of the breather. If I remember correctly, the driver side looked like it had enough room for me to get a hand in there.
Holmesuser01
Jun 10, 2014 04:22 PM
Bikedude987
Mar 20, 2012 09:41 PM
pikiluvi
Jul 5, 2005 11:02 AM
5.8turtle
Jan 19, 2005 08:04 PM
2001yellowEdge
1983 - 2012 Ranger & B-Series
Nov 17, 2003 09:16 PM
