Door handle?
Old Nov 22, 2017 | 11:31 PM
Alex from GA's Avatar
Alex from GA
Door handle?
'99 electric door locks. The drivers side spring is either broken or came off somewhere, the outside handle flops. Sometimes the key or fob won't open the door I have to get in the passenger's side and use the inside handle to unlock the door. What's the problem and how do I repair it? Thanks
Old Nov 25, 2017 | 10:45 PM
Ravenwood Ranch's Avatar
Ravenwood Ranch
well uts simple really, get the metal replacement handles from a reputable company, I know the company I used but they arnt a vendor, remove door panel disconnect connecting rod to the loch mechanism and drill out rivets from the outside, now once this is done you have two options for mounting, river it back as I did(less chance of coming loose) or bolt it in, now you have to have just enough slack on the clip when you put the rod back in after the handle is replaced, the little lever that the handle connects to has to be in the up position for the lock to fully unlock, if you have more questions message me for my number and I’ll walk you through it all
Old Nov 26, 2017 | 11:55 AM
Alex from GA
Thanks Ravenwood. Many years ago, when I lived in So Cal, I used to hunt up your way for doves and ground squirrels. I can get the handle but it's black and my truck is wine colored. Is it possible to remove the springs from the new unit and install them on the red one? Alex
Old Nov 29, 2017 | 09:03 PM
Ravenwood Ranch
I’m afraid not, the handles are riveted together and I’m unsure how well reriveting would work, but the repainting is easy, get O’Reillys to Mach color perfect using the scanner(this helps with fading) the prep and paint
Old Dec 9, 2017 | 08:56 AM
Paintjar's Avatar
Paintjar
You may be able to help me. My handle on the rear driverside door broke and the child lock is on. Is there a way to open the door with a tool?
Old Dec 9, 2017 | 09:00 AM
Paintjar's Avatar
Paintjar
Just wondering how you made out. My rear door handle broke and the child lock is on. I cant figure out how to open the door to get the panel off to repair this. Any advice? Thanks
IowaJack
2009 - 2014 F150
Dec 27, 2014 04:42 PM
Mocha Joe
Jun 26, 2013 08:28 PM
Adamjr
Sep 22, 2009 06:25 PM
tdister
General Automotive Discussion
Feb 20, 2006 09:39 AM
exlmtd
Jun 10, 2004 07:52 PM
