55 f600 starter help
Just picked up this 1955 f600. Previous owner stated he had it running recently. Signs indicate that might have been quite some time ago. New battery new starter selenoid cleaned up battery cables and terminals. Lights work but starter won't go. Jumping across solenoid starter spins. Test light on solenoid control post lit up even though starter button was not pressed? Research here says to check and replace my cables first before anything else. Instrument panel and headlights work. Had to remove starter because gear was rusted stuck any advice would be appreciated would love to get this started and around to my garage before it gets too cold
Welcome to FTE the best Ford Truck Forum on the world wide Web! All your questions will be answered here. Did you get your starter rebuilt? Does your starter spin at all? What kind of shape are your cables in? They should be 0 gauge or 00 gauge. There will be other guys along to help you pretty soon
That's a nice US Army 55 F600! Thanks for the picture. Now you need to show us more. Is there a bed on it? Do you know any history of it?
And let us know where you are from. Good luck!
Thank you for the reply. 26,000 original miles! Starter will spin when I jump across solenoid. I don't trust the cables or grounds going to work on those tomorrow. I just wasn't familiar with nothing happening my 53 6v ****** would at least give a thud and try to engage the starter. Po put dump bed on it. I turned down the giant dump box he had but got the parts to rebuild the flatbed and stake sides. He has a complete front clip with hood still if anyone is interested located in south east michigan
Howdy,
Welcome aboard!
If the starter is spinning when you jump across the solenoid, the solenoid is either wired wrong or it's failed.
If the starter spins but doesn't engage, the bendix drive is probably rusted solid.
You need to get a rebuilt starter or replace the bendix drive.(or maybe take it apart and clean it up)
Nice looking F-600! Mine looks the same olive drab!
Cheers,
Rick
Welcome aboard!
Cheers,
Rick
I forgot to mention I did pull the starter and the bendix is all rusted (mice built nest in transmission bellhousing). Previous poster mentioned that if starter spins when I jump across solenoid it is wired wrong. Isn't that the proper function of the solenoid? I am talking about jumping from battery to starter side. I still don't believe I am getting a signal from the starter button to the solenoid. Going to replace cables first. Great forum!
With these old trucks getting a good ground is important. Make sure that any surface that is part of the pathway to ground is clean and not rusty. If you get to the point of going for a rebuilt starter make sure you get one that is remanufactured in the US. I have had problems with brands that have come out of Mexican shops. The tolerances aren't as strict and when they get the starters in by the pallet it winds up being mix and match and the proper field windings and case can often be put with the wrong armeture. I had three Remy brand starters that caused problems and I finally went to NAPA and said I want an American rebuilt starter. Haven't had a problem since.
Nice truck. I would suggest you locate someone in your community that was in the military( motor pool) during the time of this vintage truck. They will have a wealth of knowledge on servicing the truck. Sometimes military applications can vary from civilian. Good luck with the project.
Gear Up (Lynn)
Gear Up (Lynn)
The huge spring loaded Bendix inertia starter drive (11350) is retained to the shaft of the armature (11005) with a roll pin (11365).
The drive has to be unwound by hand to access the pin. Then when reinstalling the drive, it has to be wound back up by hand which takes a strong hand.
It's possible that the drive is rusted solid, but the spring may have broken.
At the risk of being shot, I’ll make a suggestion. IF you are going to try to keep the engine, I’d suggest you purchase a Mini starter for a Y Block. They turn engines with high compression with ease and drive the flywheel from the engine side (original drives the flywheel from the transmission side).
I changed mine out and am very pleased with it.
If the internal contacts are burned, it may "click" but will not complete the circuit from the battery to the starter motor. You can actually drill out the rivets and open it up to view the contacts (use machine screws to replace the rivets)
None if this is really necessary though, a new solenoid is only $15-20 from most auto-parts stores.
Here's a simple test for a solenoid.
AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - Testing a Starter and Solenoid
Electrical trivia to help eliminate confusion:
A relay is an on-off switch designed to switch higher electrical loads on the secondary side through contacts.
A solenoid is also an on-off switch, but it provides linear mechanical movement such as engaging a Bendix drive to a flywheel.
If your thing is mounted on the firewall or fender well, it's a relay. If it's mounted on the starter, it's a solenoid.
Got the bendix freed up but I am confused. When I first worked it back and forth I got the gear portion to come nearly all the way down the spiral towards the spring. Now it wants to stop with a good amount of the spiral still showing. Seems that it is moving enough to engage/disengage the gear bit wanted to ask if this was normal before I put it back in. Picture 1 is all the way engaged, 2 is as far as it will now disengage.
Engaged
Disengaged
Engaged
Disengaged
