What weight oil should I use
Old 11-21-2017, 07:45 AM
CSLC12's Avatar
CSLC12
CSLC12 is offline
I am a new diesel owner. I have a 2002 ford f450 dump truck, It has 55,500 miles on motor. What weight oil should I be using for it. It has the 7.3L in it.
Old 11-21-2017, 10:12 AM
alloro's Avatar
alloro
alloro is online now
Received 4,199 Likes on 2,434 Posts
What does your owner's manual say to use? That's the fist place you should check.
Old 11-24-2017, 05:37 PM
CSLC12's Avatar
CSLC12
CSLC12 is offline
I do not have an owners manual, I live in syracuse ny so need an oil that is good for hot and cold below zero conditions...
Old 11-25-2017, 03:53 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,597 Likes on 1,302 Posts
Winter in Syracuse. God help you. I found this, it has OM info and covers all the bases:
Powerstroke Engine Oil Rquirements - Superdutypsd.com
Old 01-12-2020, 09:55 PM
OxfordWhite's Avatar
OxfordWhite
OxfordWhite is offline
I always ran 15/40 no matter what the temp and never had any issues. Block heaters cure a lot of problems with cold starts on diesels. Had a boat with twin Detroits. When you fired it up on a 70 degree day it was ugly. It started right up it was just dirty like most Detroits. The marina restaurant had customers complaining. Put block heaters in it, electricity was included in slip fees, and it cleaned right up. Don’t worry so much about oil and just keep it warm.
Old 06-01-2021, 02:13 AM
LaughingSavage's Avatar
LaughingSavage
LaughingSavage is offline
15/40 Works great either a T6 or im a big fan of M1
butchf250
Oil & Lubrication
04-13-2004 09:49 AM
Tennesseepowerstroke
05-22-2003 01:07 PM
4x4x4x4
Oil & Lubrication
10-07-2002 07:14 AM
dinosaurfan
Oil & Lubrication
11-28-2001 02:55 PM
7855F100
Oil & Lubrication
09-05-2001 10:15 AM
Quick Reply: What weight oil should I use
