7.3 Powerstroke
Old Nov 19, 2017 | 07:01 PM
greg mclaughlin's Avatar
greg mclaughlin
7.3 Powerstroke
hello, i have a 2001 7.3 and need to replace it. i bought a early 1999 before i know there was a difference. i put the bigger turbo and the wires off the 2001. it does everything except start. so i went got the computer out of the 1999 and it has a different plug. so my question is can i put the heads off the 2001 and that make the older engine work?i was told the older has smaller injectors . i don't see any other differences and don't understand why it wont start, any help.yes engine ran and was running when i pulled engine
Old Nov 19, 2017 | 07:31 PM
z31freakify's Avatar
z31freakify
Just change everything from your 01 to the e99 long block. Did 01 start before tmyou changed the engine?
Old Nov 19, 2017 | 07:36 PM
Colorado350's Avatar
Colorado350
These are the differences between the E99 and L99.
Here's some information about PCM's,
Your PCM should work in the E99.
Old Nov 19, 2017 | 07:38 PM
Walleye Hunter's Avatar
Walleye Hunter
What plug is different?
Old Nov 19, 2017 | 09:57 PM
greg mclaughlin
Yes it ran. broke a rod but was still running
Old Nov 19, 2017 | 10:05 PM
greg mclaughlin
the plug that you plug into the computer. inside the cab
Old Nov 19, 2017 | 10:07 PM
greg mclaughlin
so should i change the heads or valve cover wires
Old Nov 19, 2017 | 10:20 PM
Colorado350
Just to clarify are you talk OBD port for Bluetooth and diagnostic reading or the PCM Computer?
Old Nov 19, 2017 | 10:23 PM
Rikster-7700's Avatar
Rikster-7700
Ok let’s slow down a little here.....
What exactly have you switched over? What does the truck try and do when you try to start it? Do you have any kind of reader (search the forum for Forscan if not!) in which to read sensors and codes?
Pulling the heads and just randomly changing out parts is a very expensive, drawn out process which could all be averted if one sensor is found not to be plugged back in somewhere...
I know it’s frustrating when things don’t work the way you expect, but I guarantee you have some to the right place, and with some information and a little bit of time the forum will definitely steer you in the right direction....
Old Nov 19, 2017 | 10:52 PM
greg mclaughlin
i pulled all the sensors off the original motor and wiring harness. i was told this motor will not work. and i just cant believe i can. i have worked on simi over 30 years. just never these small trucks.and i have heads injectors
Old Nov 20, 2017 | 06:25 AM
Walleye Hunter
There is no reason that the E99 engine won't work in that swap. The differences are turbo, pedestal, plenums, spider, turbo intake tube, intake air heater up pipes and maybe a thing or two that I can't think of at the moment. Did you swap over all of the above? And I don't know what plug you say doesn't match, this is a new one on me, are you sure you're trying the right connector to the right computer?
Old Nov 20, 2017 | 11:13 AM
ExPACamper's Avatar
ExPACamper
People have done this before. You're getting good advice above. Ask and answer questions and you'll get fixed right up
Old Nov 20, 2017 | 04:14 PM
greg mclaughlin
had it scanned, shows low oil pressure low fuel pressure. i think it may be the injector o rings. everything else shows good. not getting any fuel no smoke out of tail pipe at all
Old Nov 20, 2017 | 04:33 PM
Colorado350
Can you hear the pump running? Put a 3/8 hose on the fuel bowl drain, open drain , turn key on and see if fuels flows.
Old Nov 20, 2017 | 04:34 PM
Chevota_72's Avatar
Chevota_72
You really need to get something to monitor data for us to help you. Torquepro or Forscan are highly recommended programs here and they can be used with a tablet or cell phone. You need a WiFi or Bluetooth adapter with them as well but that way we can see what is actually going on. The 7.3 doesn't monitor fuel pressure so I'm not sure who told you that was a code that came up as lo what low oil pressure are you talking about? Low ICP (injection control pressure)?
