7.3 Powerstroke
Old Nov 20, 2017 | 05:16 PM
Walleye Hunter's Avatar
Walleye Hunter
Yep, no measure fuel pressure with scanner, oil pressure neither, except for high pressure oil pressure.
Old Nov 20, 2017 | 07:38 PM
greg mclaughlin's Avatar
greg mclaughlin
yes ipc,he said not enough oil pressure to open injectors. and may need new pump. i have the one off the 2001 engine im going to put it on tomorrow.
Old Nov 20, 2017 | 08:06 PM
Chevota_72's Avatar
Chevota_72
Have you made sure all the air is worked out of the high pressure oil system? Before replacing the HPOP I would pressure test the oil rails with shop air and see if you have any internal leaks. You are just aimlessly swapping parts without being able to read what is going on with ICP AND IPC DC and FIPW.
Old Nov 21, 2017 | 04:20 PM
greg mclaughlin
i can hear a little air in valve cover when i blow with shop air. is that the injector o rings?
Old Nov 21, 2017 | 04:23 PM
greg mclaughlin
i did put it on a monitor at my local shop. he was the one saying low ipc may be orings or hpop
Old Nov 21, 2017 | 11:41 PM
Chevota_72's Avatar
Chevota_72
It could be, or it could be a stuck injector dumping the oil out of the oil spout. After i replaced injector cups on my Excursion I had two injectors doing this. I couldn't build more than 250 psi ICP. Took the injectors apart, cleaned them up and reinstalled and haven't had an issue since. Pull whatever side valve cover you hear the air under and have a look.
Old Nov 21, 2017 | 11:47 PM
greg mclaughlin
Thanks. i had less than 250 psi icp. i was told need 500 to open injectors. is this correct?
Old Nov 21, 2017 | 11:51 PM
Chevota_72's Avatar
Chevota_72
Yes at around 500 the injectors will be allowed to inject fuel.
Old Nov 21, 2017 | 11:53 PM
greg mclaughlin
i'll pull injectors tomorrow. Thanks. Sure hope that will cure the problem and it start. I think thats what it is since i dont get any smoke from tail pipe.
Old Nov 21, 2017 | 11:58 PM
Chevota_72's Avatar
Chevota_72
I would pull the valve covers and repressurize the oil rails with air and hold it for a few minutes to confirm you have a leak.
Old Nov 22, 2017 | 12:04 AM
greg mclaughlin
here is the 2001 computer and the one i got with the engine.
greg mclaughlin
Ok, Thanks i will do that.
Old Nov 22, 2017 | 08:14 AM
  #28
Walleye Hunter
The red one is an IDM and the blue one is a PCM.
Old Nov 22, 2017 | 08:46 AM
  #29
Colorado350's Avatar
Colorado350
There's the issue, trying to put the wrong thing in the wrong hole.
Old Nov 22, 2017 | 12:55 PM
  #30
Wes444's Avatar
Wes444
That's what She said!
