Best way to paint horn button
The wife makes fine jewelry and one of the techniques that she uses is cloisonné. This technique involves filing the recessed areas with a very fine powder made of ground glass. Once applied, the piece is placed in an oven and heated til the glass powder melts. The finished product is beautiful...you may want to look into this. If you don't want to do it yourself I am sure that there are artisans in your area that could do it for you. Lots of art/craft shows going on right now before the holidays, it might be worth taking a few of those in so that you can see how they look.
You need to look into this technique a little more before saying it won't work...the recessed area on the horn button is exactly what you want to fill. The ridge, the stars, and the Ford script all SHOULD be raised.
Art supplies
Abe,
Hobby / Art supply stores sell a masking fluid that is used in watercolor for keeping the white areas unpainted. It rubs off afterward. I would use masking tape and exacto knife first, then apply a thin coat of the masking fluid and remove the masking tape. I think spray etching primer and paint would give the best results. You could try a trial run on a piece of sheet metal first.
This should be easily done. Use a liquid enamel paint with retarder, paint in the center area with a brush in an even coat. Using a tight weave lint free cloth wrapped around your finger moistened with the appropriate thinner and wipe away the paint on the raised areas.
Takes some practice but you will end up a job as good as factory.
Here's my attempts so far.
I took 400 grit to clean it all up to raw.
I used Rustoleum enamel reduced with laquer thinner, the mix is your experiment. It needs to be thin enough to "run" through the recessed bits, but not so thin it waters out the color. The tiniest modelling brush you can find, let some drops fall inside the areas you want painted and roll the badge left and right, have the paint roll itself in the gaps.
Any enamel that runs up and outside the area, you can take 400 grit paper and remove the overpaint...of course once this is dry and hardened.
I've tried on an other badge that 400 is good to start with, then 600, then 1500, then 2500 wet, then Nevr-Dull polish. I'll post up a pic of mine when finished.
#28
#30
