Eaton 2 speed axle ratios
axle ratios
Mark
I’m probably like you and am used to the Timkens in my trucks having the ring/pinion teeth counts stamped into the housings. I’ve been on my own search for two speed axle info and believe I followed a Google Image trail that showed an Eaton with a letter casting that told the gear set in that Eaton two speed. I’ve also got an Eaton servicing brochure but it doesn’t say a thing about coding of gear sets. If you find an axle you’re welcome to have copies of these Eaton brochures. If nothing else is found to tell which gear set, there’s the spin a wheel method by counting drive shaft revolutions.
If you don’t already have an Eaton lined up, I’ll mention the Timken-Detroit that I picked up a couple months ago. I’m still investigating it too, but know from a brochure I found that optional gear sets for it are 5.27/7.06 and 5.64/8.16. This is a late 1930s axle having a manual shift lever. It came along with the Dayton adapter set that our friend Geno C told us about. There is a similar axle now for sale on eBay.
This is the Ebay listing in Fort Dodge, Iowa. Only drawback, it’s under a Chevy. Stu
https://m.ebay.com/itm/1951-Chevy-Tr...53.m1438.l2649
numbers???
26003 and 137688
2 speed stuff.
They sure had enough springs on that axle didn't they.
