Sponsored by: Real Truck
5R110 transmission Cold fluid exchange
Old Nov 17, 2017 | 08:37 AM
oxt127's Avatar
oxt127
Originally Posted by Sam I Am
For anyone that does this at home, it is much cheaper and more convenient to buy transmission fluid in the 5 gallon bag than per quart. And with the method shown in the video, seems like the intake tube could be connected to the bag and do it all at once.
Ok, you have my attention. Where do you do this?
Old Nov 17, 2017 | 09:11 AM
Sam I Am's Avatar
Sam I Am
What, buy the fluid? I got my last bag @ Rock Auto but any parts store should be able to order it. And it is a 6 gallon bag, not 5. By the bag is about half price vs buying quarts retail. And no one store I have found stocks enough transmission fluid of the same brand & type to do a full fluid exchange.
Old Nov 17, 2017 | 10:09 AM
geekwithoutacause's Avatar
geekwithoutacause
Do they sell Mercon V in 6 gallon bags ? Didn't know they had this. Good tip !
Old Nov 17, 2017 | 11:36 AM
Sam I Am's Avatar
Sam I Am
Yes, and motor oil too
Old Nov 17, 2017 | 11:55 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by Mark Kovalsky
Frank, that's brilliant! I wish I would have thought to do that.
Added to the tech folder in the Ex forum.
Stewart
Old Nov 17, 2017 | 12:54 PM
Misky6.0's Avatar
Misky6.0
Stewart
THAT is also awesome (as well as all the cross posts you'd done) because this is about the slickest "how-to" I've seen in a long-time... especially for something that is hard to do, not done right at the local dealer, and critical to longevity.
Old Nov 17, 2017 | 02:32 PM
wedge542's Avatar
wedge542
What we needed,i ask the mod over on the 6.0 side to add also, glad you shared the video.
Old Nov 17, 2017 | 04:59 PM
Im50fast's Avatar
Im50fast
Do they make Mercon SP in 6gallon bags?
Old Nov 18, 2017 | 04:58 AM
CollinsCD's Avatar
CollinsCD
Does anyone know what size the pan bolts are so when I go to buy longer ones?
Old Nov 18, 2017 | 06:08 AM
divideoverflow's Avatar
divideoverflow
This is great! I'm assuming it is the exact same process for the 6R140? Does anyone know if the intake tube size is the same?
Old Nov 18, 2017 | 12:23 PM
Syncrosmash's Avatar
Syncrosmash
Bolt size
The safest way to avoid cross threading is to remove one factory pan bolt and find a nut that fits it, then use the same nut on the new bolt. Be sure to run the nut all the way down both bolts to be double sure. Temporarily removing one bolt from your pan won't cause any leaks and can be replaced with no harm. Torque on the 5R110 is 11 ft lbs.
They are metric, but the new bolts measure about 1 1/4" thread length.
Frank
Old Nov 18, 2017 | 02:40 PM
Maxium4x4's Avatar
Maxium4x4
Added to the 6.0L forum Tech Folder
Old Nov 20, 2017 | 05:02 AM
  #28
CollinsCD's Avatar
CollinsCD
Frank
Thanks Frank.
Old Nov 20, 2017 | 05:05 AM
  #29
CollinsCD's Avatar
CollinsCD
One other thing I noticed is that the video says 3/4" ID tubing. Looking at the filter for my truck, I think you really need 3/4" OD tubing.
Old Nov 20, 2017 | 08:40 AM
  #30
Syncrosmash
It's 3/4 OD,
Frank​​​​​​​
