5R110 transmission Cold fluid exchange
#31
#32
In the beginning of the video just before Frank tells us how long the tube needs to be, he says to use a 3/4 inch O.D tube.
The following users liked this post:
#34
#35
on
The cooler out line is not thermostatically regulated on a 4R100 so you can simply undo one of the lines near the radiator to drain the fluid with the engine running and pour in fresh fluid through the dipstick tube like normal.
#36
My bad. I went back and played it again and he does says OD tubing. I guess listening to it at work while doing other things didn't help.
#37
Weellll, I was un-successful in duplicating this method with my 6R140. I could probably do it next time, but there were a couple of mitigating factors I ran into this time.
I used a piece of 1'' OD tubing due to the difference in trannys. The o-ring on this tranny is just a typical o-ring, not like the wide o-ring shown on Frank's video. It was 45 degrees, so the tubing was a little stiff and when I temporarily screwed the pan up, the tube just wouldn't stay in. I used 6mm x 1.0 x 60mm bolts FWIW. Next time I'll use a 90* fitting with about a 2'' section of tube going into the intake port and probably more than 3' of tubing overall. Warmer weather or some kind of heated space would probably help as well.
Still, it was good to get a new filter in there and 8 qt's of fresh fluid. We bought the truck with 39,000 miles and I could tell the tranny had never been serviced.
I found the following video to be pretty helpful as well.
#38
How does this procedure eliminate the need to heat the fluid?
And, if I should decide to blow out the cooler lines and cooler where does that old fluid go?
What model transmission do I have in our '09 F-250 5.4 and does this procedure need be used to properly change the transmission fluid in our truck?
#39
The older methods kept the pan in place. The pump picks up fluid from the pan. When the thermostat is closed the fluid doesn't go to the cooler (OK, 10% does go to the cooler when cold) but is returned to the pan. Instead of flushing with new fluid, you have a mix of old and new.
This procedure moves the pump intake to a fresh container of fluid, while the return that drops into the pan is collected and discarded. It doesn't go back into the transmission. That's the difference.
It goes into the pan with the rest of the old fluid.
You have a 5R110W, and yes, it does.
#40
As you have stated previously, heated flush is the only method besides a total overhaul to replace almost 100% of the old fluid with fresh new fluid.
FYI, I am not knocking this type of fluid exchange method as we do the best we can when changing the fluid in the AT.
#41
This method will replace at least as much as a heated flush machine.
#42
Even with this method, you still have some, not sure of percentage, co-mingling of the old and fresh fluid within the converter. One would need to use 4 quarts or more than the stated capacity to approach total fluid exchange.
#43
One last question, or two. You mentioned that when I am doing the flush I should run the transmission gear selector through reverse and all forward gears. Should the gear selector be in Park at the very beginning of the flush process and then moved through the forward gears and reverse, or should the trans selector be in the lowest forward gear position and then moved through the gears to reverse? Is there a sequence that works better than another?
Also, at what mileage increments should this flush and refill be done. I tow pretty heavy about 80% of the yearly mileage of the truck. Is every 30,000 sufficient given my driving habits?
#44
I think that's sufficient.
#45
So, one gallon of trans. fluid should be sufficient to fully exchange the old fluid left in the trans. after draining the pan?
Also, is there synthetic trans. fluid that would be advantageous to use in place of the standard Mercon V trans fluid?
The way I use our truck I really want to utilize any and all advantages in regards to fluid quality, etc.
