Can I use 1953 doors on a 1950 Ford F-1
My father is restoring my grandfather's 1950 F-1, and bought replacement doors, being told they were from a 1951 F-1. It appears they might be from a 1953. We held the door up to the cab and it appears to fit, but I wanted to ask if anyone knew we definitely could or could not use these doors, either from hinge placement, weather seals, or other issues. Thank you, Rusty.
Welcome to the forum! The doors will interchange on cabs from '48-'52, the '53 cab is totally different. If the doors appear to fit by holding them up, they are probably '51 doors as the seller said. 1953 doors would be so obviously different that you wouldn't question them. Oh, BTW, we need to see pics of your truck .
Mark
Mark
Really Nice!. I think you and I are about at the same stage. You aren't going to believe this but I'm guessing that is your headliner kit in the box across the rear frame? If so look at my pic...and honestly it's not staged. I have to delay everything and get my floor painted. I had it done but only as a protective coating as i thought it would all be covered by the mat but low and behold it's not so i just took the tank out and pull the tranny cover and floor mat. Roughed up the finish and waiting for a chance to get some matching paint on it.
