Engine/Trans issues
Old Dec 5, 2017 | 12:16 PM
baddad457's Avatar
baddad457
Originally Posted by Ckn087
Ok so if mine has one where would it be located? Drivers side intake? My engine just started making a knocking sound and it sounds like it's coming from underneath. It started after I put my first 16 oz of marvel misery oil. It's not pinging. Its more like a knock or pecking. My oil pressure gauge is either on the edge of the R in NORMAL or barely touching the N. Never stays in place. That's getting pretty low right?
Theres a hole on the flat behind the intake in the block, towards the passenger side. That's, where it would be if it had one. The first bearings to get oil starved are the # 4 & 8 rods. These are the farthest from the oilpump. So if you have a knock, that's the likely culprits. All I'll say on that pressure reading is never trust the factory gauge. Put a mechanical unit on it to actually see where the pressure is
Old Dec 5, 2017 | 04:02 PM
Ckn087's Avatar
Ckn087
Thank ya sir
dcc1993
Mar 24, 2019 10:53 AM
Eric3501
Feb 20, 2016 06:45 PM
Decipha
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
13
Mar 3, 2015 08:47 AM
4x4-jacked-up-93
Jan 14, 2011 12:19 PM
93f1504x4sclb
Sep 26, 2010 08:46 AM
