Does anyone know the Ford OEM part # for a front rotor/hub for a 1978 f250 4x4 Dana 44 axle? Can't seem to find it. Is it E1TZ-1102-D? Or will that work? Thanks!
You do know that the lug bolts (actually there are splines on the area just before the head) are what holds the hub and the rotor together? And you have to knock out the lug bolts to separate the hub and rotor.
Oreilly's part # 6084RGS $43.99 for a (1978 F250 4WD w/Dana 44 w/3,800 lbs. capacity)
Does your '78 F250 4WD have free running hubs...or not? I have to know...because the rotors are different.
I gave you all this info in post #3. The only part numbers I can give are Ford related.
Are free running hubs manual locking hubs? I'm sorry I'm confused by the terminology? And if not free running hubs then that means automatic locking hubs? Just confused... I have warn manual locking hubs on there now which replaced the stock/oem (spicer?) manual locking hubs.
thanks yeah I know I'm looking to buy together and I'm looking for oem
Oreilly's does NOT offer the hub and or can't order it. That is probably going to be a pricey part, what is wrong with yours? No worries ND will locate you some hubs, if they are on the planet.
Got it - thanks. I see a few places that offer the whole part aftermarket and oem NOS so was just gonna go with that. The wheel has play in it/ you can move it/ shake it top and bottom and it's making a grinding noise. So was going to replace wheel bearings hub rotor etc. maybe I don't need the hub?
12:00 and 6:00 play, insp ball joints. 9:00 and 3:00 insp tie rod ends. Excess 12/6 play and grinding...bearings and rotor toast if the rotor face shoes metal to metal contact IMO.
If you take it apart/insp the hub for blown races or bearings/wear past the races (highly unlikely) and just have to replace the inner and outer wheel bearings (which come with the races) and a rotor if needed. And of course aa new tap in inner side hub seal.
Put it back together and torque it properly with the 4 point socket or swap over to ratchet style lock nuts, I'd guess you should be ok.
As long as you did not burn up a bearing and mess up your spindle in the process.
yes it's at 12 and 6. Plus the axle outer shaft is very loose with lots of play. I'm worried the spindle might be toast too. I already ordered inner/outer and spindle timken bearings/races. I need to check ball joints - what's best way? When I pulled the locking hub the bearing nut was loose as well...
