Automatic shifter issue
Old Nov 14, 2017 | 08:52 PM
obwan's Avatar
obwan
Latest issue is I can't get the truck to shift out of park. It has been sitting for a while. I jacked the rear wheels off the ground and turned them to remove any pressure on the trans but no change. I disconnected the linkage from the trans, the trans will shift between the positions but the linkage will not move. I removed the steering wheel to check the shift collar and it looks fine. When I pull the shift lever forward I can see the rod depressing into the column. I assume where the linkage connects to the column under the hood it should move but doesn't. Where does this lead me?
77 F100 300 6 cyl, auto
SThompson
1961 - 1963 F100 Unibody
Aug 14, 2015 01:11 AM
410 Highboy
Aug 12, 2011 05:54 PM
teardropty
13
Jun 30, 2011 08:21 PM
cobraii
May 5, 2003 06:55 PM
