Replacement Panel Sequence
Reworked inner brace to allow door articulation.
Still needs a little work but it's close.
Too far gone. Time to try my hand at fabrication.
It's been slow moving. Haven't touched a welder in 18 years.
Pete,Sorry for the big delay. I'm on call for a week at a time at work and it took over all my free time lately.
First off, because my door gaps on either side were about an 1/8" at the top hinge at the A pillar, I trialed a couple different materials to create a gap at the bottom hinge. Ultimately, a 3/8" washer of all things ended up working the best so I decided I felt comfortable enough to move forward.
To see if new door hinges and bolts would help even more, I ordered a set (2) from LMC. I thought I would get those fairly quickly since I'm only two states away, but I was wrong so I kept moving...
Here are a few updated pics.
Quick question: Since the inner cab corners, rockers, and pillar seem to all be overlapped and connected, do I need to wait to have all those pieces on hand or just continue with replacing the rocker from the get-go?
Also, what the heck is the piece that I've circled in red? Do I need to make a replacement?
Thanks for your help as always. I can only imagine some of these questions are Dilly Dilly, I mean silly.
As for continuing or not the key is making sure that the door fits correctly. You can go ahead with the rocker to stabilize the structure but the risk is if the parts that you have coming do not match the old ones then you can't move things around to compensate. But then the door fit limits that somewhat. It would just mean a bit more trimming and massaging to get a good fit.
On the door gap, the hinges on the '53-'55, and I think on the '56, are actually adjustable. The bolt holes in the hinges are round, but the plate the bolts thread into floats behind another piece of metal. It works the same way as the striker on the door latch.
In the picture below, the arrow is pointing at the actual hole showing how much adjustment there is. Loosen the bolts in the door and the hinges slide in and out, and up and down. It might not be enough in every case, but it was plenty on mine.
Rear rocker/pillar- driver
Hard to see, but rocker/ A pillar- driver
Rocker/ A pillar-passenger
Thanks guys. Believe me, I've adjusted, adjusted, and then adjusted some more thinking that I had to of missed something. My gf gives me grief every time she walks into the garage because I'm still working on THE DAMN DOOR!
I decided to purchase just 2 hinges to give it a whirl and see what happens with the fitment. If it's worse, then you'll see a new post in the "For Sale" section. Christmas may comes early for someone so keep your fingers crossed.
As far as the mystery metal piece between the rockers and pillars, can anyone comment on that? Honestly, I'm all for eliminating the need to make new ones, but if they belong there and provide a function I should probably replace. Here are pics from the other 3 interfaces; they appear to be factory.
I know it has been some time since my last update, but I appreciate your feedback and encouragement. I think it goes without saying that I have a slight OCD problem so the whole process of not only learning to welding, but getting acclimated to welding to old sheet metal has tested my patients at certain points.
At this point I’m biting the bullet and waiting to buy a new drivers side A pillar and firewall before tacking the rocker into place. My nephews birthday party in KC sounds especially inticing considering LMC is just down the road from the undoubtlynawesome Ninja Turtle party that is about to go down! If anyone needs parts from the Sioux Falls area let me know.
Thanks again for the daily motivation!
It’s funny how tearing bad metal out snowballs.
Decent door spacing.
Drivers rear pillar.
Rocker/pillar fitment.
Wide angle view.
Clamp sheet metal between a solid/sturdy work bench and the broom stick (or whatever you are using). Use a large dead blow hammer and slowly hammer the sheet metal around the bend.
Its hard to explain, but here's a link to hammer form project I did a few years ago (CJ-3A body)
Hammer Form
The indents/vertical beads are done a little differently, but easily. If you get that far, let me know and I will show you how I did it.
All this is a lot of labor, but inexpensive and very rewarding.
Question: Is anyone using 3M seam sealer between bare metal panels (i.e. Inner corners, rockers, Eric.) with success? If so, how does that affect the plug welds to follow? There seems to be a quick dry time with the 3M so I’m curious what guys are doing before I make a mess.
