I purchased a 1987 F150 XLT Lariat with the 4.9 EFI, I plan to ship to the bahamas, My question is can I pull all the computer stuff and switch to carb? Would like to keep working on truck as simple as possible as pretty much shade tree mechincs on the island.
It CAN be done, but whether it's worth it, I wouldn't agree.
You have low-psi pumps in the tanks, and a high-psi pump in the fuel rail after the filter.
You would need another intake as well as a carb to handle the vacuum from a C6 or TV cable from the AOD, which ever you might have.
Ford switched over to EFI in mid-1986, from a computer controlled POS 1-bbl carb. Avoid it. Try to find an late 70s Autolite carb if you choose to do the swap.
It CAN be done, but I do not believe it's worth it...
