SOLVED: No Low Beams with Hi-Grade Head Lamp Upgrade Tune Up
I just got around to installing the 100/90W Hi-Grade Head Lamp Tune UP kit which I had purchased from the Bronco Graveyard last year.
1995 full size Bronco E.B. 5.8L E4OD. As far as the headlights go: 1 bulb does both High Beams and Low Beams.
On the paper sticker on the cardboard it says:
47-3662 PO 1639038S 20161121
Made in Taiwan.
On the yellow with the red border label stuck on the clear plastic hang tag cover it says:
90/100W
D4
100W High Beam
90W Low Beam
50% UP
High Beam 2000
Toyota 1A
the box next to "9007" is checked
I followed the directions, everything plugged in like it should. And high beams are working fine, but I have No Low Beams!
Any suggestions?
SOLVED: "Mechanics look to the component. Electricians look at the wiring."
I am neither, but am trying to become more of an electrician...
So my Bronco's 9007 headlight plug on the passenger side had one of the little holder clips broken off -- the one that plugs into the aftermarket Hi-Grade harness. When I pushed the plug in farther than the clip could hold it, the low beams (as well as the high beams) worked.
So now I am off to ebay to buy a 9007 replacement plug.
And in the meantime I will zip tie the plugs together tightly.
Made in Taiwan.
90/100W
D4
100W High Beam
90W Low Beam
50% UP
High Beam 2000
Toyota 1A
Any suggestions?
Tim Hodgson
1978 - 1996 Big Bronco
45
02-27-2021 08:35 AM
