460 setting lash problem
Old Nov 11, 2017 | 11:38 PM
1979brandon's Avatar
1979brandon
Hi guys. I’m almost done with my 460 rebuild. It’s my first rebuild. It’s 385 Lima. New flat tappet cam. Nothing crazy just looking to get back to factory. I reused the push rods and rocker arms. They were in great shape with very little wear. I set the lash according to everything that I’ve found and read but I keep running into the same problem. The bolts keep coming loose. I tighten the bolt until the push rod has resistance and then another 1/2 turn. I have everything installed and ready to go. I timed it without the spout to ten degrees advanced. And after a minute or two tap tap tap. Pull the valve cover and sure enough another one is loose. I’ve pulled the covers back and forth left the right then left then right like four times each. I know it’s gotta be me so what am I doing wrong.
1990 F350 460 e4od crewcab
Old Nov 12, 2017 | 12:14 AM
GNR22's Avatar
GNR22
The torque spec on the pedestal mount rockers is 20 lb/ft. They're not set like a typical stud mount.
Old Nov 12, 2017 | 09:42 AM
'89F2urd's Avatar
'89F2urd
What he said.
Old Nov 12, 2017 | 10:41 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
What these guys are saying is right. Make sure you understand the difference between stud mount and pedestal mount rockers.
However, you are right in thinking that you have to set the lash, preload the lifters. With pedestal mounts you set the lash by pushrod length and/or by shimming the pedestals.
Old Nov 12, 2017 | 10:57 AM
GoinBoarding's Avatar
GoinBoarding
With that said, if you can't reach 20 ft. lbs. on the pedestal bolt within about 1 turn of zero lash, that's when you'll need to shim otherwise the valves will hang open. Ideally, yea, about 1/2 turn from zero lash you'll hit the 20 ft. lbs. but if you don't hit the torque specs, nothing keeps them tight.
trav54
Nov 21, 2010 08:09 PM
Home made SVT
Nov 16, 2009 09:29 PM
Randoo
Oct 27, 2008 08:02 AM
ChronGen
Sep 16, 2005 08:43 AM
