So, as the title suggestions, my truck isn't doing well. Since I bought it in May I've been trying to make it stop missing under load. I've replaced plugs and wires, the coil, and fuel filter. In the last two years (I have receipts) the alternator, distributor body, MAP sensor, and IAC valve have been replaced. My next move was going to be replacing the vacuum line because I knew of a crack in the line and I was going to replace all of it. Just today I was going down the highway and I was passing someone. I hardly ever take my truck above 75 mph but I did this time. As soon as I got back into the lane, my truck turned off. It just simply died. I pulled over and tried restarting it. It turned over fine but nothing else happened. I have yet to find any leaks or lose wires. I've turned the key to the on position and can hear both fuel pumps turn on. I also sprayed starter fluid into the throttle body and nothing happened. The truck just turns over. I knida need my truck back an running pronto. Any help would be very much appreciated.
Ok, so I tried multiple times to get the codes but nothing flashes up at all when I hook up the wires. My friend and I found after running a few tests it must be something after the coil. The coil seems to be getting electricity but nothing seems to be getting to the plugs. While even just turning it over the coil got very hot. We took the coil and condenser out of my truck and threw them into my friend's 96 f150. It started right up. So, coil must be working, but electricity can't be getting to the plugs. It really doesn't help that we can't get codes, but I've tried every video I've found. So, distributor?
what engine is this? when my straight six dies like that it's the ignition module on the distributor fortyish bucks at autozone. I made a tester for it out of an led light some alligator clips and pierced the wires with needles. btw, I needed little 7mm(ithink) deep socket to get it off. I have been told that a probable reason for this failure is bad grounding and I have set off on a fix all my grounds mission. Part 1 -How to Test the Ford Ignition Control Module (Distributor Mounted)
We did pull the cap off. Everything there looks to be in great shape. I thought maybe the timing was screwed up but my truck had been running fine just a few hours before hand. I wouldn't think just driving down the highway would screw it up so bad as to make it stop running. My next thought would be maybe the points we messed up. I haven't taken a look at them for fear of taking the distributor apart and screwing something else up. However, if that's a smart next move, I'll do some research and take a look.
There are no points in the distributor. There is a stator aka PIP sensor that is well known to die. Usually it works fine until it heats up, then no signal and therefore no spark.
The link I posted previously has great step by step instructions. It starts with getting spark at the plugs, then works backwards. Follow that and you will find the root cause without spending money on unnecessary parts.
I read through the diagnostic test and it looks like that will be extremely useful. I will try it out and update y'all on what happens. Thanks for the help so far.
