Sponsored by: Real Truck
Drilling rear bumper
Old Sep 11, 2003 | 10:38 AM
mikewrt's Avatar
mikewrt
Does any one here have any sugestions on drilling into a rear bumper on a '03 250. I want to install backup sensors but don't want my new bumper to rust out when I make holes for the sensors. Any ideas, any one?
Old Sep 11, 2003 | 10:56 AM
daimon1054's Avatar
daimon1054
Just maske the area and spray it with rust resistant paint. All you are looking at is the edge of the hole nothing else will be affected. Just remember to center punch so you don't walk all over the bumper.
Old Sep 11, 2003 | 02:05 PM
mikewrt's Avatar
mikewrt
good advice. thanks
Old Sep 12, 2003 | 03:28 AM
ColtM4's Avatar
ColtM4
Cold Galvanizing spray on paint? I would imagine the zinc would protect it. But just a thought
Old Sep 12, 2003 | 06:46 AM
FortyFords's Avatar
FortyFords
Why don't you just make a bracket of some type and not drill the bumper at all.
Just my $.02
Rich
Old Sep 12, 2003 | 07:16 AM
skuteman's Avatar
skuteman
The best strategy I have found for drilling in difficult situations is startout and drill your first hole with a small bit.....say 3\16th's or so and then increase your size by 1\8 th inch increments.....until you arrive at the size you need.....Also, Ford says very explicitly that "WE" are to NOT weld on these frames as the heat affects the strength of the metal. Just what i read! s.kuteman
Old Sep 12, 2003 | 05:56 PM
hang10's Avatar
hang10
Just wondering what brand you are using? I have been looking for one of these myself but can only find these things with what appear to be, cheap, plastic discs with double sided tape. You tape them on. Looks really crappy for $175.00. I got no problem drilling my bumper.
Old Sep 12, 2003 | 07:32 PM
JoeBoost's Avatar
JoeBoost
Go to your local hardware store/Home Depot and pick your self up a thing called a Unibit. You start out with using a small drill bit , then use the unibit and go from their.
Works wonders for drilling holes in metal to the exact size you need....
Old Sep 13, 2003 | 01:17 PM
cockeyed00's Avatar
cockeyed00
does unbit have a bit that wold fit the size of ford's back up sensors? is there such thing as chrome tuoch up paint? if there is just drill holes and touch up paint the rim after drilled......
oO
Old Sep 14, 2003 | 01:05 PM
JoeBoost's Avatar
JoeBoost
Their are about 10 different sizes of a unibit you can buy. They atart out at around $30 bucks , and get higher in price the larger size you go...
Well worth the money after you use it............
Old Sep 14, 2003 | 02:46 PM
cockeyed00's Avatar
cockeyed00
Yeah, I hear yah! I bought the middle sized one it i've used it on so many things. I'm thinking of buying the set though.
Old Sep 14, 2003 | 03:27 PM
jdadamsjr's Avatar
jdadamsjr
oO
Yes, rustoleum even has chrome touch up paint... works WELL !
Our Lincoln LS's aftermarket exhaust tips started rusting on the end in the inside - looked bad so I wire brushed them as best I could and masked everything and sprayed the chrome paint and it's been fine for about 2k miles and looks great - even with the heat....
