Vac pump
Old Nov 11, 2017 | 01:37 PM
fluidp's Avatar
fluidp
Vac pump
Hi, when the vac pump starts to fail, will it make a squeaking like a failing water pump?? I have a squeaking going on and i pulled the belt and checked the pulleys, water pump, alternator and PSPump. All seems good. No leaking coolant.
Old Nov 11, 2017 | 04:52 PM
oldbird1965's Avatar
oldbird1965
I've had a couple fail and didn't hear anything.
Old Nov 14, 2017 | 01:11 AM
95F350CC's Avatar
95F350CC
My first one made a racket when it failed. The current one needs replacing due to low vacuum at start up and it is not making any noise.
Larry
Old Nov 15, 2017 | 04:58 PM
jimzpsd's Avatar
jimzpsd
If its got more than 125k miles on it, replace it. You don't want to find out the hard way. Its a cheap simple fix too, when it goes, you lose power steering, brakes, alternator, water pump, etc., and with a trailer in tow, it gets ugly real fast. If you plan on keeping the truck for a while yet, then replace the idler pulleys/bearings and a new serp. belt. Typically a water pump will not squeak, (enough to hear it at least)
Jennmiller1985
General Automotive Discussion
Sep 18, 2018 07:17 PM
Brower78
Aug 10, 2018 10:28 AM
Joe19
1997 - 2003 F150
Nov 2, 2015 10:11 AM
caperail
May 10, 2005 04:34 PM
