1978 - 1996 Big Bronco
8.8 Question
Old Sep 11, 2003 | 07:04 AM
BigFootnHawse's Avatar
BigFootnHawse
8.8 Question
Can someone tell me if the 8.8 axle from the '96 Bronco has the tubes welded in, or just pressed in. Someone looking to pick mine up asked, and it appears the typical holes going through the housing to the tubes are filled. Could this be welded from the factory? If so, can they be easily drilled out so the tubes can be removed?
Thanks,
