Speedo adjustment
Old Nov 10, 2017 | 04:10 PM
Dan B.'s Avatar
Dan B.
Originally Posted by Tricon
Not sure that I'm following you. The size is in the spreadsheet. You change the end of the second octet to 4C from 00 in order to change the speedo to a 285/75R18...which just so happens to be almost exactly the same size as a 35" (34.81" or 4 revolutions per mile off) tire. Its dead on with GPS for me. If you want another size you have to find the hex value to get it. Anything larger than that 285/75 though will throw a CEL.
Speedometer Recalibration for Different Tire Size
BCM 726-12-01 xxxx xx00 xxxx --> xxxx xx4C xxxx
Forum comment: "Original tire size 275/70r18, New size 285/75r18. No DTC codes after 900 miles. This is a small change. Larger tire size changes do calibrate the speedometer but a check engine light will persist."
In the spreadsheet thread H2Ocamper just provided the info for where all o.e. tire size values are. My dealer reprogrammed mine for the OE 20” size for my 35’s and like yours is dead nuts on GPS w/no cel’s or warnings. Great info!
https://www.ford-trucks.com/forums/n...ply&p=17582784
Old Nov 14, 2017 | 09:23 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
its going to be temping to go back up when i do 37's and just deal with a cel . The he code works really well and it only took a few drives to come to my final value posted. I will probably wind up just rolling with a cel to have an accurate speedo
Superduty.pride
32
Oct 14, 2011 07:11 PM
edmundo7
2004 - 2008 F150
Mar 6, 2008 06:40 PM
ReAX
Computer Chips & Tuners
Mar 1, 2008 11:58 PM
Fluid Power
Jun 12, 2007 08:30 PM
stang3O2
1997 - 2003 F150
Mar 25, 2005 01:25 PM
