I got a free van! ‘91 E150 camper conversion project
Old 10-28-2017, 11:10 PM
RonGonzo's Avatar
RonGonzo
RonGonzo is offline
I was given this van a few weeks ago. I’m a real estate broker and my client wanted it out before wslisted her property for sale.
Deal!
Here she is...
The van had not run in ten+ years. All four tires were flat and the front passenger was completely off the wheel after rolling the van back so we could work on it. The roof liner is mint but the front seats and carpet are in pretty bad shape. I’ll likely be removing most of the interior.
My buddy and I grabbed some tools, an air compressor, and battery from his 302.
The first thing we did was break the compressor. Next it took us an hour to get the hood open only to find out the battery we brought was dead.
Day one ended up being pretty disheartening but we’d be back.
The next weekend we had a new battery. We decided to bleed the fuel lines and I think it’s a good thing we did. The gas coming out was yellow.
After we topped off the radiator I hopped in and gave the key a turn. It sputtered a bit, I gave it some gas and it fired right up! I couldn’t believe it.
We had a smooth idling van but no tires. We loaded up the tires and filled them at the gas station. Once they were on we came back after a few hours and all four including the spare to replace the mangled tire held air.
It was time for a test drive. I’m sure there was a dozen things we should have checked but we were excited and decided to try around the block and see if there was any issues. Sure enough after backing out of the drive way and putting it in drive the transmission was slipping pretty bad.
I was not sure we’d make it back to the drive way but it was down hill and my buddy basically rolled in with enough speed to get us in and up the driveway.
Turns out out we had next to no transmission fluid.
HE
So that’s where I’m at with the van now. I know basically nothing about wrenching on vehicles and have already learned a ton. Looking forward to this project!
Question time.
How much damage if any do you think was done to the transmission driving a few hundred feet practically dry? My friend said something about the tourque converter getting a few years off its life.
Is this the ‘Club Wagon’ trim? We’re 90% sure the engine is the 302.
What should I limit the camper conversion weight to? I just want a bed, some storage, and an ‘all in one’ kitchenette that will be behind the left barn door. I don’t want to overload the van.
I’m sure there will be many more questions to come.
Thanks for reading!
Old 10-29-2017, 02:54 PM
NICKSAN's Avatar
NICKSAN
NICKSAN is offline
Good deal
I like your motivation, If you stick with it you will feel the gratification of bringing a vehicle back from the grave.
Have Fun
Old 10-30-2017, 09:07 PM
fordman75's Avatar
fordman75
fordman75 is offline
Nope, the Club wagon is a window van. The rear side windows will match the height of the door windows. The Club Wagons are the passenger style vans. What you have is a conversion van.
This is my bucket of a E350 Club Wagon.
You should be able to confirm the engine by the decal under the hood.
5.0L = 302
5.8L = 351W
or decoding the Vin# will also tell you which engine.
Old 10-30-2017, 10:10 PM
maples01's Avatar
maples01
maples01 is offline
You have scorched the clutches in the transmission, you should have checked the fluid but it was most likely parked due to transmission issues, you best be figuring on replacing it because I'm guessing it's gone.
Old 11-12-2017, 12:00 AM
RonGonzo's Avatar
RonGonzo
RonGonzo is offline
We just drove it 20+ miles! It’s pretty loose but runs great.
Here’s a quick update video.
Old 11-12-2017, 01:16 AM
maples01's Avatar
maples01
maples01 is offline
Boy I would love to have that rear AC unit, an HVAC guy said those are the best due to being mounted high, the oil runs back down to the compressor.
motorcarmike
02-22-2016 07:59 PM
Jmanb13
01-06-2016 01:28 AM
tabijan
11-10-2015 10:33 PM
PStruwing
10-06-2015 05:27 AM
MrNightman
06-29-2015 07:45 AM
Quick Reply: I got a free van! ‘91 E150 camper conversion project
