1951 F1 tranny project
My new horn wire from Bob Drake didn't have that piece - nor anything crimped on at the top, just the bare wire. I didn't have any luck getting it resolved with them, so put the old stuff back in. Ross, what's the purpose of the gray foam down inside, next to the steering wheel hub? Thanks! - Bob
Bob, I got the correct wire from DC, as I recall. I still have the one pictured, which I cut some off the bottom, and is missing the fiber washer (still has the plastic piece). The insulation is oily but not cracking. If you want it I can throw it in the mail.
I don't think I put the foam in there, I assume it's to keep noise down? or electrical insulation? It was >10 yrs ago, CRS....
Bill, the wire is supposed to come with a brass piece crimped on the top end and a bullet on the bottom.
I bought that horn wire in '91 and the package is still unopened. Got it because I thought I remembered the horn wire was frayed the first time I replaced the steering gear, in the 1970's. When I changed the steering gear the second time in 2013, I was going to replace the wire but found the new one had just the one terminal. You can see it in the picture above. Turned out my original wire was still fairly good, so put a piece of heat shrink tubing on it. Thanks for the offer Ross, but "I'm good" with this one. Mine doesn't have that foam piece - I don't think it's original. You should just be looking at the metal hub (with the puller holes) after you take off the nut, and the cup with the spring. My steering wheel is cracked in about the same places as yours! Electrical tape and a "lace on cover" is better than spending $200, at least for a work truck.
- Bob
- Bob
