Sponsored by: Real Truck
Engine Swap
Old Nov 4, 2017 | 11:57 AM
Medic25275's Avatar
Medic25275
Engine Swap
I have a 2008 F250 Crew Cab 4x4 with the dreaded 5.4. I have already replaced the timing set twice and I am constantly dealing with an unreliable engine. on a good day this engine is under powered. Buying a new truck at the moment is not an option. So I am thinking about swaping the motor for the new 5.0 or even the new 6.2. I know I will have to replace the computer and probably the wiring harness But other that that what issues will I have? Will these motors bolt up to the bell housing i currently have. Ive see a couple company selling kits to update to the drive by wire etc... Thanks in advance.
Old Nov 4, 2017 | 12:24 PM
seville009's Avatar
seville009
I’ve got a 2006 5.4l that was improved greatly by a 5 Star tuner I put in it. I did that after I got a 2011 6.2l because the 2006 5.4l felt so under powered after driving the 6.2.
I’m just throwing that out as something you may want to try before swapping engines.
Old Nov 4, 2017 | 03:54 PM
texinwa's Avatar
texinwa
I have a complete 6.2 with trans and transfer case if you decide to go that route.
Old Nov 6, 2017 | 07:41 AM
jcook77's Avatar
jcook77
From what I understand this is next to impossible without a complete donor truck.
Old Nov 6, 2017 | 12:00 PM
FractureCritical's Avatar
FractureCritical
nothing is 'impossible', but locking up the cam phasers (if not done already) and slapping a centrifugal supercharger on the 5.4L should get you same or better power with a lot less heartache and cash outlay.
foreverfordtrucks
2004 - 2008 F150
Jan 29, 2017 12:55 AM
67 Bronco
2004 - 2008 F150
Jul 22, 2015 08:18 PM
knipdlo
Modular V8 (4.6L, 5.4L)
Dec 29, 2013 11:54 AM
nathan-F-250
Oct 13, 2010 08:41 PM
fair67driver
Jun 5, 2010 10:35 PM
