The 360 Engine....
Hope you are all enjoying your Fall.
I've never seen anything nice said about the 360ci engine, ever. I've always heard it's a "dog" it's a "boat anchor" or it just flat out "sucks". I am wondering why this is the overall opinion? I've had a few F100's and right now I have my first F100 (a one owner 1969 F250 Camper Special) with the 360ci and a 4 speed manual. Haven't had much of a chance to drive it yet as it only arrived last week.
My question is: what makes this a bad engine as opposed to the 352ci and the 390ci (both of which I've had in my other F100s)?
Would like to know people's opinions.
Thanks,
Keith
Stroke: 360 = 3.50" .. 390 = 3.78."
So, the only difference is the crank, rods and pistons. EVERYTHING else is the same.
My 360 only had 64k original miles on it and outside of a tuneup didn't seem to need much else other than a carb rebuild and a standard tune up.
360 plus 4spd, use 4.10 gears. with auto trans, use 4.10 or 3.73 gears
390 plus 4spd use 3.73 gears, with auto trans use 3.54 gears
410/428 plus 4spd or auto trans, use 3.54 gears
If you have the 360, you can get away with the 3.73 rear end ratio as long as you're not overloading the truck, going up long steep hills, etc. But what you'll find with heavy loads and long steep grades is that the 360 will start to labor sooner and drop speed more rapidly. If you're not using the truck for pulling heavy loads or going up long steep grades, the 360 will be just fine, for the most part. Because of the low final ratio, the 360 causes a sacrifice in fuel economy at higher road speeds and imposes an upper limit on road speed that is lower than you'd have for a 390.
The 360 is probably not anybody's favorite FE because of the short stroke and thus loss of torque, but it's a tough and serviceable engine. If yours is original to the pickup and you're getting along fine with it, leave it be. If you rebuild it in the future, consider a 390 rotating assembly at that time.
I'll add:
360 or 390 with a 5-speed, opt for a 3.90 gear gear.
Most of mine were kept fairly stock and I have had a few that ran better than the average 390, and a few that were not so good. All this can happen with any engine of that vintage due to sloppy manufacturing and things like core shift when casting heads and blocks, clearances and balancing.
But to quantify my experience, much of it came when fuel was formulated a lot different and back when the speed limit was 55 on interstate and not 80 like it is now. The 4.10s were just fine for running 55-60 but not so much for running 70-80. For all but heavy towing, the 3.73s will be just right all around with a 30-31" tall tire and no overdrive. You should still be ok with a lighter trailer and hauling a car.
I think most of the bad reputation comes from ignorant people who don't know how to properly tune and maintain an engine, like the people who feign hatred of a quadrajet carb to cover for ignorance of not knowing how to make it work right.
Try not to use any gas with alcohol, those old carbed engines do not like that crap and it will eat rubber.
Rebuild the carb with the modern Ford kit and you will not have issues with the modern gas and the carb.
I had first hand that 360's were bad engines as they were the first engine
ford used to take a crap with people who owned them with big campers on them.
As willowbilly put it was the unleaded gas that was the #one killer back in the day'
Many of the people who owned them were the models of the c/s ranger that had a large cab over Camper on back.
When putting those 360's under heavy working loads the 360's Camper/Special Rangers got a workout with those big c/s and they held up until people started putting in the 87 unleaded gas.
By using the unleaded gas under some conditions would cause the Exh. Valves an seats to get hotter
than normal that causing them to become red hot. Under this condition it would slowly burn away as molten metal Cinders that would cause the engine to back- fire out the carb.
Over time of putting the ford 360 motor into the days that the EPA was forcing an end of
leaded fuels was the main reason for the clean air act that
broth on the death of the 360 engines sooner in the f100 if they where worked hard.
The f250- f350 was the last models that could run on the leaded gas.
By the mid 70's rolled around many states stopped using any of the leaded motor fuels.
Where as the f100 were suppose to run unleaded gas sooner into the early mid. 70's
As for the mid 70's rolled by the word was out that the ford 360 was a junk motor an now in 76 the EPA forced feed to us 86 octane that really did in the ford trucks.
With so many motor vehicles falling ill on 86/87 octane the EPA was force to bump up the octane to 87 that became laws across the US. Some states a person could buy high octane gas. Which was a back log of stored fuels until it was used up.
Just about this time most all were in need of all in need of a valve jobs.
1974/75 ford trucks were all needing repair by this time frame for the f250-f350s rolled by.
Ford also had troubles with push rod lengths on the 360 if the heads were milled to much.
If a person did not keep the push-rods in order they could run into a problems.
I don't remember the 332 & the 352 having this push rod troubles.
1970/72 Passenger Cars, F100/Bronco/Econoline sold new in CA have it, but other states may not have mandated it.
1973: FoMoCo changed the fuel tank filler tubes with Evap/Em by putting a restrictor in them. Back then there were two different sizes of filling station nozzles.
The unleaded fuel nozzle was smaller in diameter, so the restrictor would not allow the larger in diameter leaded nozzle to fit in.
Sold new in CA 1973/78 F100/350's have Evap/Em. By 1979, all states mandated Evap/Em.
Leaded fuel was available for many years and it is still available at some filling stations. The Union Oil station in Brentwood (WLA) has it for about 10 bucks a gallon.
360/390 use the same pushrods, one type was shared with the 352. In fact, the only difference between a 360 & 390 is the crank, rods and pistons. EVERYTHING else is the same.
In 1968, FoMoCo made a "running change" with FE pushrods. 1965/67 352 and some 1968 360/390 pushrods are 9.62" overall length (C4TZ-6565-B).
Some 1968 360/390, 1969/76 360/390 pushrods are 9.59" overall length (C8AZ-6565-A). The 9.62" pushrods were still available, but were referred to as .030" O/S (oversized).
